Can CoDeSys SP RTE communicate with SQL?
varkai73
2006-12-01
2009-09-09
  • varkai73 - 2006-12-01
    How can RTE communicate with SQL? Example?
  • Anonymous - 2009-09-09
    Originally created by: roger.kunz@axista.ch
    Hello
    There is an easy way to communicat directly between a control and a SQL-database.
    With the driver SQL4automation (small Windows application) you can write and read data directly from and to a database with SQL-syntax in the control.
    You need only a ethernet interface on the control and a windows platform in your network for running the application SQL4automation.
    More information at: http://www.sql4automation.com/
    Roger
