It is currently Tue Feb 18, 2020 2:28 pm
Post new topic  Reply to topic  [ 16 posts ]  Go to page 1 2 Next
PostPosted: Tue Mar 12, 2019 7:22 am
Hello!
There are no problems with the physical interface can0, everything works.
We want to use the virtual can (vcan) interface in the Beaglebone Black controller from the CoDeSys environment, but it does not work.
I activate the virtual can in the controller with the following commands:
 $ modprobe vcan
 $ sudo ip link add dev can2 type vcan
 $ sudo ip link set up can2
Through ifconfig I see that this interface appeared in the system.
Utilities can-utils work with it without any problems.
BUT, if you add this interface number (2) to the can bus in the CoDeSys project, then after loading the project into the controller, an error appears in the log that the device could not be configured.
What could be the reason?
I tried to remove the bitrate setting from the file rts_set_baud.sh because vcan does not support this setting, but it did not help.
PostPosted: Sat Mar 16, 2019 10:33 am
No one can help? I also wrote help on the store, also silence. Maybe the manufacturer is not interested in selling?
PostPosted: Sat Mar 16, 2019 7:02 pm
not sure if vcan is supported by CODESYS.. don't think so.
Let me check.
PostPosted: Wed Mar 20, 2019 7:27 am
what do you want to archive with this virtual CAN / vcan?
Maybe you need to explain a little more in detail.
PostPosted: Wed Mar 20, 2019 12:19 pm
you could give the following solution a try (wihout guarantee that this will work)
[CmpSocketCanDrv]
ScriptPath=/opt/codesys/scripts/
ScriptName=rts_set_baud.sh
InterfaceName=vcan
not sure, if it will work (did not try) but sure is either vcan will work or the real interface not both at the same time
I guess.
PostPosted: Thu Mar 21, 2019 5:51 am
Thanks, Edwin!
Let's try today or tomorrow.
The reason for using vcan is an implementation of automatic switching between two physical can interfaces, unfortunately the driver built into CoDeSys cannot do this. Correct if I'm wrong.
PostPosted: Fri Mar 22, 2019 2:26 pm
Using the "InterfaceName = vcan" parameter does not help,
but this setting is somehow applied runtime because after that the physical can interface also stops working.
Record in CoDeSys log
and the output of the command "ifconfig vcan2".
Using the InterfaceName = vcan parameter does not help, but this setting is somehow applied runtime because after that the physical can interface also stops working. An entry in the CoDeSys log.
The output of the command "ifconfig vcan2" in the attachment.
I noticed that even in normal mode, the setting "Baudrate = Use current setting" does not work
(and when setting a specific speed it works)
PostPosted: Thu Mar 28, 2019 3:18 pm
Hello!
Until now, there is no solution.
And the ticket on store.codesys.com is closed with redirection to this thread in the forum: (
Are there any other ideas that you can try other than "InterfaceName = vcan"?
The test bench is on and available at any time.
PostPosted: Fri Mar 29, 2019 7:08 am
come on,
this is not good stile to post here screenshots from store requests!
Need some time....
PostPosted: Fri Mar 29, 2019 11:36 am
at the moment it is not possible to mix it up and use vcan and real can at the same time in CODESYS.
If you need this this need to be done by a improvement tracking entry ….!
PostPosted: Thu Apr 04, 2019 6:28 am
Hi!
NOT! I don't need to use real and virtual can at the SAME TIME! I need ONLY a virtual can! And the string "InterfaceName = vcan" does not work! Help me please! Already so much time there is no solution :(
PostPosted: Thu Apr 04, 2019 3:55 pm
I see no workaround...
it is possible to use CAN ( as interface name) but it stops after 2 interfaces... (hard coded)
PostPosted: Thu Apr 11, 2019 8:21 am
Hello, Edwin!
Excuse me, really, the "InterfaceName = vcan" setting works!
The problem was that the number of CAN interfaces used by CoDeSys should be no more than 2.
Now there is another problem, how to use the vcan interface?
The Candump utility program does not see the packets that the CoDeSys sends to the CAN bus via the vcan interface.
For the physical CAN interface, this is not a problem. You can view the packets on the bus using another device, and for virtual CAN I did not find a suitable solution.
Forwarding packets with socat or cangw utility programs
work ONLY to receive packets in the direction of CoDeSys
socat INTERFACE: can0, pf = 29, type = 3, prototype = 1 INTERFACE: vcan0, pf = 29, type = 3, prototype = 1
or via cangw
cangw -A -s can0 -d vcan0
cangw -A -s vcan0 -d can0
Thus, packet transmission in the direction "CoDeSys -> vcan0-> can0-> physical CAN device" does not work
But it works in the opposite direction.
How to solve this problem?
Most likely the reason is that when you open a socket in the Canopen CoDeSys driver, loopback mode is disabled:
int loopback = 0;
       if (setsockopt (s_fd_write [byNet], SOL_CAN_RAW, CAN_RAW_LOOPBACK, & loopback, sizeof (loopback))) {
               DEBUGP ("setsockopt (CAN_RAW_LOOPBACK):% s", strerror (errno));
If this is true, then how was the virtual can interface supposed to be used? After all, virtual can works only through loopback (correct, if I'm wrong).
PostPosted: Tue Apr 23, 2019 5:10 am
It took almost 2 weeks, but no answer!
At the same time, the ticket on store.codesys.com is closed!
Help me please!!!
PostPosted: Tue Apr 23, 2019 3:33 pm
give this a try:
[CmpSocketCanDrv]
Loopback=1
