https://forum.codesys.com/
CODESYS Control for BeagleBone SL use shared library
https://forum.codesys.com/viewtopic.php?f=26&t=9001
Page 1 of 1
Author:  myemail for codesys [ Mon Jul 23, 2018 7:54 am ]
Post subject:  CODESYS Control for BeagleBone SL use shared library
CodeSys 3.5.12
Target: Beaglebone black with PicoScope 2000
I have .h and .so files for picoscope on Beaglebone black and want to use CODESYS to control the picoscope connected to beagleboneBlack. Is that possible? It seems I need to use "CODESYS Control for BeagleBone SL". What else do I need to have from Codesys?
what I found online:
1. "Creating and Linking External C Library Functions" v1.0 is a bit out of date.
2. C-integration? Does Beaglebone has it? I have add "c implemented library" into my own library. But can not find out how to use them.
3. "C code runtime component /toolkit" from the link below. looks like a solution for me but found no documents for it.
viewtopic.php?t=8422
Should I wait for the workshop in Sep. to know if it is the right solution for my project?
I am new on Codesys and IEC61131-3, any input with details will be very appreciate!
Author:  Aliazzz [ Mon Jul 23, 2018 7:56 pm ]
Post subject:  Re: CODESYS Control for BeagleBone SL use shared library
What exactly are you trying to achieve, i.e. what is your project goal /intention?
Author:  myemail for codesys [ Tue Jul 24, 2018 10:17 am ]
Thanks for the reply, Aliazzz!
The final system will use picoScope to measure something. it is conected to BBB and show the result on a touch sceen.
So I need a application running on BBB to control and process the datas from picoscope.
Now I am trying to use codesys to develope this application. The picoscope has driver for debian on BBB. But how to use
it in codesys?
Author:  myemail for codesys [ Thu Jul 26, 2018 7:31 am ]
I have put same question on CODESYS Store helpdek - 'my question'.
No feedback at all like here...
Author:  Aliazzz [ Thu Jul 26, 2018 8:57 pm ]
Though it probably can work, I have no experience with an oscilloscope in combination with a PLC runtime.
That said, I guess accessing the scope from within Codesys can (hopefully) be achieved by adding a serial device in codeys (i.e.) adding the usbdevice "port" into Codesys Config file like the following example.
My suggestion would for you to find out how you can add USB COM access to Codesys;
cd etc/
sudo nano CODESYSControl.cfg
[SysCom] Linux.Devicefile=/dev/ttyAMA
However, I have got no clue on how you can read or control the device/channel/dac data. For such details you should study the device driver / use the C integration route. It is possible to integrate C code into Codesys. However C integration requires a license. For this I suggest contacting Codesys Sales directly.
Just tackle your problem one step at a time. I hope you will succeed and will share your adventures with us!
Good luck and let us know how you are doing with this.
Aliazzzz
Author:  myemail for codesys [ Mon Jul 30, 2018 1:51 pm ]
Thanks! Aliazzz,
I have gotten answer from Codesys Support Team.
"it is not possible to include the .h or .so file direct to our runtime.
The only way I see is that you create a own application with that files as an gateway and send the current values via SharedMemory or TCPIP to our runtime."
Hope this is helpful to peoples who have similar problem.
Author:  Aliazzz [ Sat Aug 04, 2018 3:49 pm ]
I am glad it seems there is an alterrnative way via SharedMemory or TCPIP.
There should be some demo projects via the Codesys store available that demonstrate this.
Good luck.
https://www.phpbb.com/
