It is currently Thu Jul 18, 2019 3:28 am
PostPosted: Tue May 08, 2018 11:46 am
I installed free codesys 3.5 sp12 patch3+ (64bit)
and beaglebone black wireless (running with bone-debian 9.3 lxqt)
then update BBB from codesys. Installed the package v3.5.12.30.
But always can not detect the target with IP Address.( Tried with USB and Wifi)
Anyway I can get the status as below:
root@beaglebone:~# service codesyscontrol status
● codesyscontrol.service - LSB: Prepares and starts codesyscontrol
Loaded: loaded (/etc/init.d/codesyscontrol; generated; vendor preset: enabled)
Active: active (exited) since Sat 2018-05-05 23:31:16 UTC; 7min ago
Docs: man:systemd-sysv-generator(8)
Process: 7753 ExecStop=/etc/init.d/codesyscontrol stop (code=exited, status=0/SUCCESS)
Process: 7794 ExecStart=/etc/init.d/codesyscontrol start (code=exited, status=0/SUCCESS)
May 05 23:31:14 beaglebone systemd[1]: Starting LSB: Prepares and starts codesyscontrol...
May 05 23:31:14 beaglebone codesyscontrol[7794]: Backup licenses
May 05 23:31:14 beaglebone codesyscontrol[7794]: tar: Removing leading `/' from member names
May 05 23:31:15 beaglebone codesyscontrol[7794]: chmod: cannot access '/sys/bus/i2c/devices/0-0050/at24-0/nvmem': No such file or directory
May 05 23:31:15 beaglebone codesyscontrol[7794]: pid 7813's current affinity mask: 1
May 05 23:31:15 beaglebone codesyscontrol[7794]: pid 7813's new affinity mask: 1
May 05 23:31:16 beaglebone codesyscontrol[7794]: codesyscontrol started
May 05 23:31:16 beaglebone systemd[1]: Started LSB: Prepares and starts codesyscontrol.
After "Stop" then "Start" the runtime in "beaglebone black" tab. The status changed:
Active: active (running) since Sat 2018-05-05 23:56:47 UTC; 3s ago
Process: 20520 ExecStop=/etc/init.d/codesyscontrol stop (code=exited, status=0/SUCCESS)
Process: 20563 ExecStart=/etc/init.d/codesyscontrol start (code=exited, status=0/SUCCESS)
Tasks: 13 (limit: 4915)
CGroup: /system.slice/codesyscontrol.service
├─20581 /opt/codesys/bin/codesyscontrol.bin /etc/CODESYSControl.cfg
└─20596 /opt/codesys/bin/codesyscontrol.bin /etc/CODESYSControl.cfg
May 05 23:56:45 beaglebone systemd[1]: Starting LSB: Prepares and starts codesyscontrol...
May 05 23:56:45 beaglebone codesyscontrol[20563]: Backup licenses
May 05 23:56:45 beaglebone codesyscontrol[20563]: tar: Removing leading `/' from member names
May 05 23:56:45 beaglebone codesyscontrol[20563]: chmod: cannot access '/sys/bus/i2c/devices/0-0050/at24-0/nvmem': No such file or directory
May 05 23:56:45 beaglebone codesyscontrol[20563]: pid 20581's current affinity mask: 1
May 05 23:56:45 beaglebone codesyscontrol[20563]: pid 20581's new affinity mask: 1
May 05 23:56:47 beaglebone codesyscontrol[20563]: codesyscontrol started
May 05 23:56:47 beaglebone systemd[1]: Started LSB: Prepares and starts codesyscontrol.
While in this mode, I can "scan network" and find the BBB, and login BUT only a few minutes( if not seconds) The codesyscontrol service changed back to active(exited). And the dialog "No connection to the device. Please rescan your network" pop out. The scan network will not work except I do the routine "stop" then "start" again. But it only last for few minutes.
Above situation tested with both USB and WiFi connection. I will try this on the second BBB later to exclude the hardware problem.
Thanks!
Chen
PostPosted: Wed May 09, 2018 9:18 am
The 2nd BBB wireless has same behavier. :(
Is BBB wireless not supported by codesys at all?
Just found other topic
https://forum.codesys.com/viewtopic.php?f=26&t=8766
And two years before
https://forum.codesys.com/viewtopic.php?f=26&t=7471
PostPosted: Wed May 16, 2018 10:18 am
yes at the moment this not supported!
Could you please write a 'feature request' to the CODESYS Store helpdek - 'my question'?
