It is currently Wed Oct 23, 2019 11:58 am
PostPosted: Mon Mar 20, 2017 10:35 am
Is posible to connect Codesys with BeagleBone Black with a Profinet dispositive? And if it is posible how can I do?
Thanks.
PostPosted: Tue Mar 21, 2017 11:50 am
I see a Profinet network in available devices.
Try this:
Rightclick on Device (your Beaglebone) => Add Device => Profinet IO => Ethernet Adapter => Ethernet => add device => close window
Right click on Ethernet => Add Device => Profinet IO => add what you want: IO Device if BBB is a slave or IO Master if BBB is a master => add device => close window
Right click on new added device => Add Device => add your IO, Drives which was previously registered in Tools=>Device Repository
Is this what you are looking for?
PostPosted: Sat Mar 25, 2017 8:45 am
there is one little problem doing profinet on BBB.
Think the internal networkcard does not work.
You need to test it with a usb to ethercat Adapter.
PostPosted: Wed Mar 29, 2017 11:03 am
Thank you.
I connected the BBB like Master with Ethernet connection to the Profinet "ET 200S IM 151-3 PN HF", but sometimes the BF (bus error) is flashing with red color. And appears this:
Station status: CF81FD05
Connection aborted: AR consummer DHT expired.
Why happens this problem? Is it possible to connect via Ethernet or do I have to connect via USB with an USB to Ethernet adpater?
Regards.
PostPosted: Wed Mar 29, 2017 5:52 pm
either performance issue - reduce reduction Ratio..
or check the task cycle for the profinet io update Task,
it is by default 1ms does this work for BBB?
