It is currently Sat Feb 22, 2020 10:00 am
PostPosted: Thu Mar 09, 2017 11:23 pm
I did kernel update as described by Edwin
viewtopic.php?f=26&t=5652&start=30#p15463
I have tried kernel 4.4.14-bone-rt-r11, tried 4.9.13-bone-rt-r4
https://www.rcn-ee.com/deb/jessie-armhf/
also tried 4.4.52-ti-rt-r91
https://github.com/beagleboard/linux/co ... ertCNelson
Every time when I update to RT kernel I loose SSH access to BBB.
In case of problem with SSH, BBB FAQ says:
Delete the file called "dropbear_rsa_host_key" in the location of /etc/dropbear/.
Then you need run the command '/etc/init.d/dropbear start'.
After update to RT kernel directory /etc/dropbear/ does not exist and no command /etc/init.d/dropbear
Any suggestions how to activate SSH?
Thanks
PostPosted: Tue Mar 14, 2017 1:36 pm
I have the sampe problem. Have you solved it?
PostPosted: Wed Mar 15, 2017 1:29 am
In Putty choose "Serial" instead of SSH, change COM1 to COM3, leave speed at 9600.
Open connection and login as root. If invitation doesn't come left-click inside putty window on the cursor and wait 15-30sec.
If doesn't work, connect monitor, keyboard, mouse to beaglebone and do steps below in terminal. Open terminal and login as root.
First try to regenerate host keys:
rm /etc/ssh/ssh_host_*
dpkg-reconfigure openssh-server
If doesn't help, delete keys,
Reinstall SSH server. Beaglebone has to see Internet, connect Ethernet cable.
apt-get install openssh-server
If doesn't work, regenerate keys again:
In my case I have got SSH working. In your case please post the result in this thread.
https://wiki.debian.org/SSH
