It is currently Thu Jul 27, 2017 1:37 am
PostPosted: Tue Nov 01, 2016 5:44 pm
I'm struggling to figure out a way to communicate with two serial devices in codesys v3.5 SP9 + BBB rev C.
I use both uart2(ttyO2) and uart4(ttyO4) ports. I can successfully communicate using only one uart port by appending the following line in /etc/CODESYSControl.cfg:
[SysCom]
Linux.Devicefile=/dev/ttyO
portnum := COM.SysCom.SYS_COMPORT1;
I use the example project available in the store: SerialComWithVisu with the following call to the FB Serial_Line
FirstSerialLine(
      slMode:= SL_READWRITE,
      udiPort:= 1, //tty02 ???
      udiBaudrate:= 115200,
      paParity:= COM.PARITY.NONE,
      sbStopBits:= COM.STOPBIT.ONESTOPBIT,
      udiByteSize := 8);
Everything works fine. I can write and read out of ttyO2.
Then i added the uart4 (ttyO4). I wired Tx4 -> Rx2 and Tx2 ->Rx4. I tested the communication with a python script and i was able to read and write from both serial devices.
Following the thread http://forum.codesys.com/viewtopic.php?f=21&t=5699&start=15, i left unchanged the CODESYSControl.cfg and i added a second call to the FB setting 2 as COM2
SecondSerialLine(
      udiPort:= 2,
      udiByteSize := 8);
Both ports udiPort 1 and 2 open with no errors and the write function returns successfully. The read function instead always returns empty string. Moreover if i execute
 cat /dev/ttyO2 or 4
no output is returned as no one is actually writing in that file. I tried to change the udiPort value but ANY value i type gives the same result.
What is the right way to handle two serial devices in parallel in codesys ?? Should i edit the CODESYSControl.cfg file to declare the second port too ? if yes, how ?
Thank you.
PostPosted: Thu Nov 03, 2016 11:54 am
hi,
have you tried
FirstSerialLine( slMode:= SL_READWRITE, udiPort:= 3, //ttyO2
and
FirstSerialLine( slMode:= SL_READWRITE, udiPort:= 5, //ttyO4
another one posibility is to set symbolic links for your ports... in Linux.
PostPosted: Thu Nov 03, 2016 2:25 pm
It works like a charm now. I used udiPort 3 and 5 as you suggested!
Leaving the CODESYSControl.cfg unchanged as i wrote it in my last post, The mapping between tty and COM in codesys is of the type: ttyOx -> COM(x+1), isn't it ? Hence, why must the udiPort be equal to 1, if i use only one uart port (e.g. ttyO2) ? What is the meaning of
in CODESYSControl.cfg when two or more ports are used ?
Sorry to bother you with all these questions but i'd like to understand better how the serial mapping works. It may be also useful to others.
Thank you.
PostPosted: Sun Nov 06, 2016 3:31 pm
you could remove this line, make no sense.
only:
[SysCom]
is needed.
