It is currently Thu Jul 27, 2017 1:36 am
Post new topic  Reply to topic  [ 53 posts ]  Go to page Previous 1 2 3 4
PostPosted: Thu Jul 21, 2016 1:47 pm
I agree with the misstype
kernel src you see in the script will be pulled from:
https://rcn-ee.com/repos/debian/pool/ma ... -upstream/
if you execute ./update_kernel.sh –kernel 4.4.14-bone-rt-r11
on later updatesyou need only to call
./update_kernel.sh and you get the newest sources..
PostPosted: Thu Jul 21, 2016 3:00 pm
how to specify that I need a realtime kernel?
Edwin, could you please help with Startup script, where is it?
PostPosted: Fri Jul 22, 2016 7:14 pm
which startup script for doing what?
For Setting the CPU Clock?
Always an option is to google the bbb forum here there is always a solution for all kind of Problems:
http://beagleboard.org/Community/Forums
maybe this link here helps for setting the CPU clock:
http://beaglebone.cameon.net/home/set-cpu-speed
Keep in mind for rt_preemt/realtime it is mandatory to have a stable cpu clock no matter if it
is set to always beeing fast or slow - important is constant.
PostPosted: Thu Aug 25, 2016 3:45 pm
Why is the BBB considered Industrial capable and not the RPi? Is there because there are extended temperature range versions available, or is there some other reason to believe it is more reliable?
PostPosted: Tue Sep 13, 2016 5:04 pm
Dear Edwin,
am i able to use SPI somehow on Beaglebone with codesys, because i've seen on your example screenshot (store)? If it possible, how can i add this?
PostPosted: Tue Jan 17, 2017 11:34 am
Hi Edwin,
I am using codesys on beaglebone black but found it very slow and consuming all CPU. I used the same program with Raspberry PI and was ok. Due to industrial propose I go BBB.
I followed codesys recommandations to install it. How to check that I may did something wrong?
Can you help please?
Thank,
Pape
PostPosted: Thu Feb 23, 2017 4:06 pm
I need your help people. I create a simple program to turn the light on using GPIO, and after logging in codesys says :"downloaded:exception" and does not let me start thr application.
PostPosted: Fri Feb 24, 2017 6:26 am
yes this is a known bug at the moment...
please map the whole word and access:
for example
wOutput.0
in your application.
