It is currently Mon Dec 09, 2019 5:43 am
 Post subject: open dialog from library
PostPosted: Fri Aug 09, 2019 4:13 pm
If I define a visualization as a dialog, and include it directly in my project, I can open it with no problems (using a button object, input configuration OnMouseClick, Open Dialog). If I move the dialog to a library, and update the button to open the dialog from the library, nothing happens.
Is there any reason I shouldn't be able to open a dialog box from a library?
PostPosted: Mon Aug 12, 2019 6:50 am
Hello tvm,
no there is no reason for that and I was not able to reproduce your issue.
Which compiler-verison and visu-profile are you using?
Best regards,
Marcel
PostPosted: Tue Aug 13, 2019 12:42 am
I'm using Schneider SoMachine, which uses Codesys v3.5.3.87. There's an upgrade coming soon, I'll try again with the new version.
thanks for the reply
