It is currently Tue Feb 18, 2020 7:39 pm
PostPosted: Thu Jul 25, 2019 4:14 pm
Hello Everybody, my first post here.
I can't find my way to add an on screen command (it's a touch panel) to shut down the HMI runtime just like "Alt+F4" would do.
That's because it happens that there's no keyboard connected.
Thanks for you help.
Marco
PostPosted: Mon Jul 29, 2019 3:06 pm
Hello Marco,
you can add the library ComponentManager and then use CMShutdown(0).
Best regards,
Marcel
PostPosted: Tue Jul 30, 2019 9:17 am
Hello Marcel,
thanks for your reply, but I still can't make it:
I added the library Componentmanager, then added a pushbutton with the properties shown in the attached image, compiled, downloaded into target, the button is there but on click nothing happens.
Any suggestion?
Thanks, Marco
PostPosted: Tue Jul 30, 2019 9:35 am
Hello Marco,
no, that should work.
Please report the issue in the store using the "my question" feature (https://store.codesys.com/).
Best regards,
Marcel
PostPosted: Fri Aug 02, 2019 4:09 pm
they say it's a well known issue.
The suggestion is to use the taskkill function.
I've decided to write a simple "Stop HMI.bat" file:
taskkill /F /IM CoDeSysHMI.exe
and execute it by means of my on screen command:
And all went good...
Hope this helps,
Marco
PostPosted: Sun Aug 04, 2019 7:41 am
another option would be to use
close only the HMI screen ( not the HMI itself):
"C:\Program Files\3S CODESYS\GatewayPLC\VisualClientController.exe" --application=Application --flags=2
open it again:
"C:\Program Files\3S CODESYS\GatewayPLC\VisualClientController.exe" --application=Application --flags=1
guess better then the hard way ;-)
PostPosted: Mon Aug 05, 2019 8:45 am
My bad, I tested it with a HMI, which was not installed as a service and there it worked fine...
Best regards,
Marcel
