It is currently Wed Feb 26, 2020 4:19 pm
 Post subject: multiple user to WebVisu
PostPosted: Tue Oct 09, 2018 7:44 am
hi ,
suppose i have a simple structure
TYPE Data_Structure :
   STRUCT
      data1:BOOL;
      data2:BOOL;
   END_STRUCT
END_TYPE
then I make a visual (just 2 lamps) for this structure and declare in the interface Editor
VAR_IN_OUT
   dataItf:Data_Structure;
in main PLC, i instantiate 2 instance from this structure.
in Main Visualization, i can switch between 2 instances by "switch frame variable".
my problem is , if 2 people access the WebVisu Same time.
personA want to see instance1 visu,
personB want to see instance2 visu.
i found that not working. they affect each other.
anyone can help.
