It is currently Sat Feb 22, 2020 5:41 am
PostPosted: Thu Aug 16, 2018 1:28 pm
With Visu Utils library it's very easy to open dialog from code.
But how I can close it with this library?
Make CODESYS great again
PostPosted: Mon Aug 20, 2018 5:19 am
Edwin, hope on your advice. :P
I need something like that:
PostPosted: Fri Aug 24, 2018 5:15 pm
Any ideas? :?:
PostPosted: Fri Aug 24, 2018 11:51 pm
I have not used visu utils but this is how I have closed dialogs in the past using this function:
*This function needs to be called from the same task as your VisuElems.Visu_Prg*
We had a button that set the PLC_PRG.xCloseDialog to TRUE
My understanding is you can't use the "CurrentVisu" Variable when using this. Hope this helps a little.
PostPosted: Sat Aug 25, 2018 3:18 am
Thanks, it's seems like a solution.
Your function is not use sDialogName (so it works as "CloseAllDialogsForAllClients"), but I understand how I should edit code for my task.
I'm very appreciated.
I hope 3S include same FB in Visu Utils in next SP's.
PostPosted: Mon Aug 27, 2018 4:24 pm
Does anyone knows if this works also in TwinCat 3?
PostPosted: Mon Aug 27, 2018 5:07 pm
You are correct e.kislov and sorry about that. Was a solution for something else we were experimenting with. To do a specific dialog you would change it to this:
PostPosted: Wed Aug 07, 2019 1:52 pm
Vielen dank.
It works very well under TwinCat3.
tschüss
cron
