Dynamic text in library
switcher
2018-03-28
2024-02-27
  • switcher - 2018-03-28
    I like to make visualization function block in library, which uses Dynamic texts from text list.
    Text list is configured in Codesys project, not in lib.
    All works ok if I make the same visualization function in Codesys project, but don't work if I put this visu fb in library.
    Should I set some reference (pointer?) to define function block to use specific Text list from Codesys project?
    Or that is the procedure to make this work?
    Thank you!
    Best regards,
    Zdenko.
  • sturmghost - 2024-02-27
    Did you found a solution?
