peterraj86 - 2018-01-17
Hi..Friends,
In HMI, I create the Table with 4 columns like Fault Description,System,Date/Time and count to view the Real time error. I used the dynamic Text (*.xml) for fault Description.
Due to length of Error, I cann't see full fault Description. I try to reduce font size and font format as well as to remove column also. I couldn't see the Description.
If the Text is running from start to end continuously, which is useful to see the Fault Description.
Can you please give the guidance to resolve this issue.
