I need to represent the graph for two variables. The two variables have a different scale, so I need to have two ordinates axes. Is it possible to do it with a same trend ?
The purpose is to use the same trend for multiple variables.
I can use the multiple check boxes and set the variable desired, but then I don't know how to change the trend at runtime.
Do you have some advises for this problem ?
Gianluca
Originally created by: gianluca strocchi
Gianluca
It's possible since SP7.
For example, check it, page 23:
https://www.codesys.com/fileadmin/data/ ... SP7_en.pdf m
