It is currently Fri Jul 28, 2017 6:04 pm
 Post subject: AlarmManager
PostPosted: Tue Nov 29, 2016 5:18 pm
Hello
The Alarm Manager has a good example. But I do not see why I got it not to run...
My Problem is:
Example to set a Error is described..
Alarmmanager.AlarmGlobals.g_AlarmHandler.RaiseEvent(Alm_AlarmConfiguration_Alarmgroup_IDs.ID_AlarmGroup1, Alm_AlarmGroup1_Alarm_IDs.ID_0);
the thing is.. if I push F2 to see the variables I can only see the Alarm_ID's and not the AlarmGroup_ID's.
Why is that?
In the table example it is the same but not in the AlarmManager example.
I do not want to copy the hole example of the AlarmManager to my project
What do I have to do to make it work???
Attached you will find the Picture from the InputAssistant which is in the example.
I can see number 2 but not number 1.
Thank you for any help
 Post subject: Re: AlarmManager
PostPosted: Tue May 16, 2017 10:47 am
I had the same problem with 3.5.9.40.
What I did as work-around is change my project to use compiler version 3.5.7.70 and visualisation profile 3.5.7.4 (changing nothing else). Then I could choose them.
See the "project settings" of your project to change this (temporarily).
At 3S-Smart Software Solutions this is a known issue and registered as Jira issue CDS-52260.
PostPosted: Sat Jun 17, 2017 1:18 am
You might have figured it out by now, but just click on "Set all to newest" and AlarmManager project will load fine
