It is currently Wed Oct 18, 2017 11:59 am
 Post subject: Open dialog via IEC code
PostPosted: Mon Nov 21, 2016 4:19 pm
Hi all,
I'm trying to open a custom dialog in my project (Codesys 3.5.9.30) without success.
I created a "Visualization" set as dialog with a couple of buttons and a rectangle with text.
In my main page, when the user click a button, I have to perform some operations and then, if the operations are completed, I need to open this dialog.
I tried with this code:
VAR_GLOBAL
    dialogMan : VisuElems.IDialogManager; // Dialog manager
    openSaveDialogConfirm : VisuElems.IVisualisationDialog; // Reference to the custom dialog
    pClientData : POINTER TO VisuElems.VisuStructClientData;
    visuRect : POINTER TO VisuElems.VisuStructSimpleRectangle;
// In my PLC_PRG
IF dwOperationResult = 0 THEN // The file already exist. Ask for overwrite
    GVL.openSaveDialogConfirm := GVL.dialogMan.GetDialog('Dialogs.ConfirmDialog'); // Get the reference to the FileOpenSave dialog
    (* Check if the dialog exist, if so try to open it *)
    IF GVL.openSaveDialogConfirm <> 0 THEN
        GVL.visuRect := ADR(GVL.pClientData^.rClientRect);
        xResult := GVL.dialogMan.OpenDialog(GVL.openSaveDialogConfirm,ADR(GVL.pClientData),TRUE,GVL.visuRect);
All references to the objects are set, the variable xResult becomes true but the dialog is not displayed.
I have no clue because the documentation is missing, can you help me?
Thank you,
Massimo
PostPosted: Tue Nov 29, 2016 8:57 pm
Take a look here viewtopic.php?f=25&t=7385
You can open dialog for each "logged" users on certain application event
PostPosted: Wed Nov 30, 2016 8:43 am
Yes, you copied the example from codesys store; I did the same thing.
Actually my question becomes: why should I use OpenDialog4? What are the other three functions used for?
PostPosted: Wed Nov 30, 2016 12:38 pm
Here is simplified
PostPosted: Wed Nov 30, 2016 2:28 pm
Thank you
