It is currently Wed Oct 18, 2017 12:08 pm
PostPosted: Sun Nov 13, 2016 6:16 pm
I've duplicated a group of graphic objects, and need to make the same change to all variables in the duplicated objects -
i.e., change Array[1] to Array[2]
Then duplicate again, and search/replace Array[1] to Array[3], and so on.
When I select 'Selection Only' and click 'Replace All' it tells me, 'Search scope 'selection only' is not supported for this editor'.
So I then select 'Active Editor' and 'Find Next' then 'Replace', I get the error msg: 'Value cannot be Null. Parameter name: stBlock'
So what is the proper way to do this? Am I missing something?
PostPosted: Sun Nov 20, 2016 10:35 am
you need to expand group and select all elements you need to replace
PostPosted: Tue Nov 22, 2016 5:10 am
Thanks for your reply. Can you elaborate on 'you need to expand group'? What does that mean?
PostPosted: Sat Nov 26, 2016 11:56 pm
Just select all object you need
