It is currently Sat Nov 18, 2017 10:13 pm
PostPosted: Thu Nov 10, 2016 3:21 pm
I wanted to change my visualization theme. It worked fine for everything except the buttons. Any suggestions? I am running Codesys on a Raspberry Pi 3.
Greetings
Andreas
PostPosted: Thu Nov 10, 2016 11:50 pm
I would recommend to check if these Images which you add to the the Imagepool are downloaded to the PI.(on project download -> use the CODESYS Filebrowser to check if the files are located in /PlcLogic/visu)
Somtimes large and lower case in the filename sometimes cause these Problems
+ check the plc logger
PostPosted: Mon Nov 14, 2016 9:41 am
I switched to one of the standard Codesys styles (white style). In the filebrowser I couldnt find the button elements of the white visu.
The log shows the following:
