Export history alarms
sbiughy
2016-10-12
2017-11-24
  • sbiughy - 2016-10-12
    is it possible to export the history alarms (stored in sqlite) to a csv file?
  • Anonymous - 2016-12-14
    Originally created by: Massimo.Milluzzo
    Log into the application > Right click on AlarmStorage > CSV export of Alarm Storage
    IMG: export_alarms.png
  • sbiughy - 2016-12-15
    Thank you very much for answer.
    This option is available for each device? I have a Wachendorff HMI but I have not the same menu.
    Is it possible to execute the export procedure also by software. I'd like to export alarm history to a usb drive.
    Best regards
  • stephan-K - 2017-08-03
    I'd like to know as well if it is possible to execute the export procedure by software to usb. Any ideas?
    Thanks
    BR,
    SK
  • e.kislov - 2017-08-04
    I also suggest this function for Trend.
    And I think there is should be option "Record format": .sqlite or .csv with selected path (for example, I need to write it to USB flash).
  • freedumz - 2017-08-20
    I used Eaton PLC and this way didn't work with this brand
    So I wrote a small programm which catches alarms and store them automatically in a csv file on the memory card of the plc
  • pedro-ant - 2017-09-04
    freedumz hat geschrieben:
    Could you upload that program so we can see the approach that you've used?
    Thank you very much in advance.
  • stephan-K - 2017-11-24
    If someone could post a program to catch alarms for logging (probably as an array of strings) that would be greatly appreciated.
    Thank you.
