It is currently Thu Nov 23, 2017 6:19 am
 Post subject: Export history alarms
PostPosted: Wed Oct 12, 2016 10:31 am
is it possible to export the history alarms (stored in sqlite) to a csv file?
PostPosted: Wed Dec 14, 2016 11:36 am
Log into the application > Right click on AlarmStorage > CSV export of Alarm Storage
PostPosted: Thu Dec 15, 2016 8:37 am
Thank you very much for answer.
This option is available for each device? I have a Wachendorff HMI but I have not the same menu.
Is it possible to execute the export procedure also by software. I'd like to export alarm history to a usb drive.
Best regards
PostPosted: Thu Aug 03, 2017 6:40 pm
I'd like to know as well if it is possible to execute the export procedure by software to usb. Any ideas?
BR,
SK
PostPosted: Fri Aug 04, 2017 1:38 pm
I also suggest this function for Trend.
And I think there is should be option "Record format": .sqlite or .csv with selected path (for example, I need to write it to USB flash).
PostPosted: Sun Aug 20, 2017 10:36 am
I used Eaton PLC and this way didn't work with this brand
So I wrote a small programm which catches alarms and store them automatically in a csv file on the memory card of the plc
PostPosted: Mon Sep 04, 2017 8:44 am
Could you upload that program so we can see the approach that you've used?
Thank you very much in advance.
