It is currently Tue Jan 28, 2020 6:54 pm
 Post subject: Message in Visualization
PostPosted: Thu Jan 14, 2016 1:33 pm
Is it possible to prompt messages in the Visualization? If yes, how can I do that? Or which library can I use?
What I want to do is to send a message in the Visualization in case the "start button" haven't pressed.
Something like...
IF xStart THEN
xStartProcess := TRUE;
ELSE
XStartPorcess := FALSE;
//PROMPT MESSAGE IN VISUALIZATION ('Please press start button to start')
END_IF
PostPosted: Thu Jan 14, 2016 7:48 pm
I'm doing this by button element field which is hidden / shown as specific value says.
Look for "State variables" then "invisible" and "Deactivate input". Default is TRUE = HIDDEN / DEACTIVATED, so if do you want FALSE for HIDDEN you have to put "!" after variable, like "XStartPorcess!"
PostPosted: Fri Jan 15, 2016 3:27 pm
I tried what you said but it didnt work. I have done a screenshot in the places where you said I should put "!".
PostPosted: Fri Jan 15, 2016 3:36 pm
its OK, if g_Stop is FALSE you have to see your element visible and active for touch (click) event.
g_Stop must be BOOLEAN type.
Have you any error message in log?
PostPosted: Wed Jan 20, 2016 3:13 pm
Sorry, because I answered you too late. It is true that the initial status TRUE = HIDDEN but with "!" has no effect. Still TRUE := HIDDEN.
PostPosted: Wed Jan 20, 2016 8:23 pm
It's long time when I used it, I dot'n remember exact type. And I have not CODESYS on this computer right now.
Maybe it required ( ).
PostPosted: Mon Sep 12, 2016 10:45 am
hi
please used NOT before your variable .
its works
