I want to use Desktop PC as client in codesys for HMI Visualization purpose.
My required configuration is : one Development Station and 3 HMI system Desktop PC and 2 HMI system as Touch Panel.
Is this configuration possible or I need to Use Touch Panel only ?
I have attached System Configuration for reference
Pls help
guess a good option is to use RemoteTargetVisu:
You could start it here:
"c:\Program Files (x86)\3S CODESYS\GatewayPLC\RemoteTargetVisu.exe"
Is Remote target Visu same as using WEB VISU or different ?
What Protocol Remote Target VIU will follow? Is it OPC?
If there is any manual for its configuration then please send me the link.
Also Kindly clarify following:
If I right click on Visualization Manager then three option comes , which case to Use HMI Visualization and which case to use Remote Target Visualization. Web Visualization is already clear/understood to me.
1. HMI Visualizations
2. Remote Target Visualization
3. Web Visualization
Rgds,
Himanshu
himanshu hat geschrieben:
Rgds,
Himanshu
Pls help
Codesys HMI Configuration.pdf [59.82 KiB]
which plc and which version are you using?
Hello Edwin,
I am using Hitachi PLC. Vendor Name - Hitachi Industrial Equipment systems co Ltd/ Hitachi -IES.
Codesys Version is 3.5 SP8
Rgds,
Himanshu
Rgds,
Himanshu
http://www.dimoulas.com.gr/PDF/WAGO%20P ... Visu_E.pdf
Regards
