It is currently Sun May 26, 2019 2:01 pm
PostPosted: Thu Jul 14, 2016 2:30 pm
Is it possible to write to a variable of type TIME without converting.
If I use a rectangle with %d, it will display 1000 (meaning T#1S).
But if I try to write to it, it does not work.
I would like to be able to write 2000 and then my variable would be set to T#2S.
I know I can do it by converting in the program but I was thinking that if it can read correctly it would be possible to write also.
Thank you.
PostPosted: Thu Dec 15, 2016 7:02 pm
Is this possible or not?
PostPosted: Fri Dec 16, 2016 4:48 am
I believe you have to enter T#2000ms or T#2s. Just like you have it in the code. I always just convert a number to time in the code.
Scott Cunningham
KEB America, Inc.
www.kebblog.com
www.kebamerica.com
PostPosted: Thu Apr 26, 2018 10:45 am
Very old post but yes, it's possible. I personnally use REAL type variables to set time values. For example, enter your time value in seconds in real type (%.1f) on HMI. Lets say 1.5s. Then on the program side you have to make conversion to type TIME:
tTime := REAL_TO_TIME ( fTime * 1000). Code turns given time value (1.5s) in real type to time format t#1500ms...
PostPosted: Fri Apr 27, 2018 1:09 pm
attached an example:
