It is currently Tue Feb 18, 2020 8:15 pm
PostPosted: Thu Jun 02, 2016 6:59 pm
Good afternoon,
We have a PLC/HMI product that will run a shareware pdf reader called FoxIt. Does anyone know if there is a way to use a button in Visu that will open this reader, maybe to a specified document?
PostPosted: Sat Jun 04, 2016 5:50 am
in which Visu type do you want to see this pdf viewer?
Internal Visu CODESYS , TargetVisu on the plc, Webvisu in the Browser ?
PostPosted: Thu Jun 16, 2016 10:11 pm
Good afternoon Edwin,
My apologies, I got away from this project for a while.
I am using the TargetVisu on the PLC.
I almost have it working - I can activate the PDF viewer. My only issue is that I can only specify a document to open that is in the same folder as the pdf viewer.
Is there a way, with the 2nd parameter when you activate a file, to specify a file path to the document to be opened?? I have attached a picture below.
Thank you!
PostPosted: Tue Jan 14, 2020 6:59 pm
Could you explain how you to open PDF on browser ? Which program you use to do this ?
Thank you very much.
PostPosted: Wed Jan 15, 2020 12:19 am
Add the WebBrowser visu element
point to the url of the pdf.
https://help.codesys.com/webapp/_visu_e ... n=3.5.15.0
PostPosted: Wed Jan 15, 2020 8:52 am
Pdf are store on sd card of raspberry, not with url....
PostPosted: Wed Jan 15, 2020 8:56 am
galexis how is the browser supposed to download the file and view it, if it is not available for the client to get it?
E.g. you have a pdf called "manual.pdf".
Put the pdf file into your $PlcLogic$/$visu$ folder.
You should then be able to download the file using http://localhost:8080/manual.pdf (or include it into your website as I-Campbell described two posts ago).
Best regards,
Marcel
PostPosted: Wed Jan 15, 2020 9:23 am
Ok,
it work with:
- Put the pdf file into your: $PlcLogic$/$visu$ folder.
- Add button with internal command navigate to : 'http://ip_of_plc:8080/your_PDF.pdf '
