Table Control on an array using a constant for its size.
2016-01-06
2016-01-08
  • yannickasselin1 - 2016-01-06
    I am trying to use the table control.
    It works fine when linked to an array of struct defined like this:
    var
    astMyStruct: array [0..9] of ST_MyStruct;
    end_var
    It also works fine when linked to an array of struct defined like this:
    var constant
    c_iNbElement: int := 10;
    end_var
    var
    astMyStruct: array [1..c_iNbElement] of ST_MyStruct;
    end_var
    But it does not work when linked to an array of struct defined like this:
    var constant
    end_var
    var
    astMyStruct: array [0..c_iNbElement- 1] of ST_MyStruct;
    end_var
    Is this a bug?
    I like to use constants to define array sizes and I like to keep all my arrays 0 based.
    But if I keep working this way, I cannot use the table control with my arrays.
    Thank you.
    eschwellinger - 2016-01-08
    I have added a bug in our tracking db.
    Should be fixed.
  • yannickasselin1 - 2016-01-08
    Thank you.
