It is currently Mon Jan 27, 2020 3:54 am
PostPosted: Tue Jan 14, 2020 5:23 pm
I make backup of persistant on sd card, with date and hour name, with AppStoreRetainsInFile.
Question 1: is it possible to store backup files on external USB flash disk ?
Question 2: I would like to choose with webvisu, which backup file I have to restore, with AppRestoreRetainsFromFile. How to make chooser of file ?
PostPosted: Wed Jan 15, 2020 12:39 am
1. Yes.
2. Create a button with the input configuration set to open the Visu dialogs.fileopensave as per https://help.codesys.com/webapp/_visu_d ... pen-dialog
PostPosted: Wed Jan 15, 2020 9:05 am
1- How ? On raspberry, it's : "/mnt/sdb1" ?
I use this code:
PROGRAM MEMORISATION_PERSISTANTS
VAR
fbDelete : FILE . Delete ; (* bloc pour effacer le contenu du
fichier *)
sFileName : STRING := 'data.ret' ;
pApp : POINTER TO APPLICATION ;
Result : RTS_IEC_RESULT ;
xInit : BOOL ;
RESTORE : bool ;
END_VAR
//CmpApp + CAA File + SysTypes Interfaces
IF NOT xInit THEN
   pApp := AppGetCurrent ( pResult := ADR ( Result ) ) ;
    xInit := TRUE ;
    RESTORE := TRUE ;
    PERSIST_RESTAUREES := FALSE ;
 END_IF
IF SAUVEGARDER = TRUE AND NOT RESTORE THEN
   fbDelete ( xExecute := TRUE , sFileName := sFileName ) ;
   IF fbDelete . xDone OR ( fbDelete . xError AND fbDelete . eError = File .Error . NOT_EXIST ) THEN
      fbDelete ( xExecute := FALSE ) ;
      IF pApp <> 0 THEN
         Result := AppStoreRetainsInFile ( pApp , sFileName ) ;
      END_IF
END_IF
IF RESTORE THEN
   Result := AppRestoreRetainsFromFile ( pApp , sFileName ) ;
END_IF
I have to specify ?
sFileName : STRING := '/mnt/sdb1/data.ret' ;
2- I don't understand how to use dialogs.fileopensave ?
I put it on vizualisation ? And after? Which configuration of it ?
Or I create a button, on mouseclick, I call dialog box fileopensave ? But What I have to set about:
parameter : filelistprovider; type: VISU_FBFILELISTPROVIDER; Value : ????
PostPosted: Fri Jan 17, 2020 3:16 pm
Point 1 :
I do auto mount usb disk on /media/usb with user pi.
On sFilename I do: '/media/usb/data.ret'. It work.
And for point 2: I need help !
I analyse example VisuDialogST, but the second application which can help me, doen't work. Please help me !
PostPosted: Mon Jan 20, 2020 11:41 am
Edwin, could you help me !?!
