It is currently Wed Feb 26, 2020 7:01 pm
PostPosted: Fri Aug 23, 2019 3:42 pm
Wago 750-8212
CODESYS Control for PFC200 SL 3.5.14.30 Installed and executing applications just fine.
When I log into the web admin.
Selecting any meaningful sub menu option results in the following message.....
Any help with a resolution greatly appreciated.
Edit: It used to work. I only discovered this after a few weeks of development I went to change the IP address of a NIC and discovered I could not.
PostPosted: Fri Aug 23, 2019 7:47 pm
Hm...
never seen this.
Which Wago firmware is on that PFC?
Sure the workaround is:
Login by putty/ssh and do the same with:
cbm
This is the linux shell based... management command.
PostPosted: Mon Aug 26, 2019 7:13 pm
Firmware Revision: 02.08.35(11) (From web admin this bit works)
cbm
 WAGO Console Based Management Tool
 Controller Details
 Product Description..........WAGO 750-8212 PFC200 G2 2ETH RS
 Order Number.................750-8212
 License Information..........Codesys-Runtime-License
 Firmware Revision............02.08.35(11)
 Q or RETURN to quit
I have a ticket with CoDeSys, and through that they requested 'df' from SSH command line...
root@PFC200V3-449FEA:~ df
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/root               245679    234335         0 100% /
devtmpfs                252580         4    252576   0% /dev
none                    252580        48    252532   0% /tmp
none                    252580         0    252580   0% /media
none                      4096        96      4000   2% /var/log
none                    252580        52    252528   0% /var/run
none                    252580         0    252580   0% /var/lock
none                    252580         0    252580   0% /var/tmp
tmpfs                   252580        56    252524   0% /run
/dev/mmcblk1p1           65382     22952     42430  35% /boot
/dev/mmcblk1p5         2031432      7300   1919276   0% /home
PostPosted: Mon Aug 26, 2019 9:39 pm
No free space left...
Remove /root/codesys... .deb packages..install files
PostPosted: Mon Aug 26, 2019 10:43 pm
Being new to Linux. I need to be sure I understand your response.
Are you saying that under dev/root/ I'll find a /CoDeSys folder. and under that I should delete *.deb files (or better still, remove the entire /codesys folder)?
Would be really nice if the "firststeps_codesys_control_for_pfc200_sl_en.pdf" document addressed this with a section entitled 'cleanup'.
PostPosted: Tue Aug 27, 2019 5:52 am
This is a bug, the debian packages on using
the update tool to deploy the runtime are not removed after installing them.
So the procedure is:
Login by ssh client an delete the files which have codesys
... .deb .
Then you should see around 89-90 % used space on the flash.
The bug is solved with 3.5SP15 runtime.
If you see still
100%... a reset origin device by rightclick in the devicetree in CODESYS... will delete all files which are dowloaded by CODESYS
PostPosted: Tue Aug 27, 2019 2:29 pm
I tried to find "the files which have codesys... .deb" but my Linux muscle is weak.
So I reset origin.
/dev/root               245679    222880      9692  96% /
And now the web admin works again.
Veilen Dank for the help.
I'll be upgrading to codesys to SP15.
