It is currently Fri Oct 18, 2019 7:24 pm
Post new topic  Reply to topic  [ 14 posts ]
PostPosted: Fri Jul 12, 2019 2:07 pm
I am evaluating codesys, i have a Janztec eMPC running codesys RTE x64 with softmotion
I am able now to use my axis via canOpen command, i would like to have an example in softmotion to be able to synchronize this two axis
PostPosted: Mon Jul 15, 2019 9:31 am
just ust the examples from the SoftMotion package:
"c:\Program Files\CODESYS 3.5.14.0\CODESYS\Projects\SoftMotion\4.5.0.0\Examples\Tutorial\PLCopenMulti.project"
To have them running with your axis, just add CANbus-CANopenManager_SoftMotion_ followed by your drives.
(rename the virtual axis from the example.
PostPosted: Tue Jul 16, 2019 12:15 pm
Edwin Schwellinger wrote:
thanks Edwin,
do i need to set up something special for the axis PDO ? when i try to use with my axis i am not able to control it
PostPosted: Wed Jul 17, 2019 2:46 pm
depends on the drive.
Which drive is it?
PostPosted: Thu Jul 18, 2019 6:55 am
Which drive is it?
elmo Gold twitter CanOpen
PostPosted: Thu Jul 18, 2019 11:28 am
is this device CIA DS402 compliant?
Could you attach the EDS?
PostPosted: Thu Jul 18, 2019 4:19 pm
hi
here is the file
PostPosted: Sat Jul 20, 2019 8:57 am
I would give this a try:
PostPosted: Mon Jul 22, 2019 7:09 am
Edwin,
When i add the SM_DRIVE402 generic device to my elmo drive the mode of operation(0x6060) is always set to 8
this is controled by the driver ? is it possible to select another operation mode ?
PostPosted: Mon Jul 22, 2019 7:37 pm
you could use MC_Power, MC_Move... all PLCopen Fb's.
If you want to command the axis manually ( do everything by your own) no need to add the SoftMotion drive...
But it is alot easier with the functionblocks.
PostPosted: Tue Jul 23, 2019 11:05 am
hi even if i am not using any function block
my mode of operation is set at 8, is it the SM_genericDS402 driver which set that value is it possible to modify it, that enable only cyclic synchronous position mode
PostPosted: Wed Jul 24, 2019 6:50 am
at the moment you could not change this manually ( I mean if you use the SoftMotion drive the modes are commanded by the driver/Softmotion)
But usually this is how to use it... I guess you just need to figure out why your drive/axis is in error state.
If it is a DS402 compliant drive you may adjust these values here for your drive:
Keep in mind that this additional page/views only occure if you enable Tools-options->device editor-> show generic device configuration views
By the way with the upcoming 3.5SP15 release there is a new function to make it possible to write manually the PDO's from the application.
(SMC_SetController mode to 0 ) will decoulple the mappings to the SoftMotion FB's.
PostPosted: Thu Aug 01, 2019 3:25 pm
I update to codesys 3.5SP15
i have no more error on my SM_Drive_GenericDSP402
i still have my mode of operation blocked at mode 8
PostPosted: Wed Sep 18, 2019 2:21 pm
hi
i have updated codesys to the last release when i try to open sample project
i have now this error:
cron
