i219-v Ethernet Controller driver
LooijmansR
2019-07-01
2019-07-03
  • LooijmansR - 2019-07-01
    I have two different Intel NUC's, one with an i218-v as Ethernet Controller, and one with an i219-v. The cmpet1000drv installs properly on the i218-v NUC, but it fails on the i219-v NUC (the installation keeps running for app. 5 minutes and then displays it has failed).
    The NUC with the i219-v has more resources and thus I'd like to use that NUC. I have tried modifying the .ini file to support the i219-v hardware IDs but unfortunately it isn't that easy as it looked.
    I came across this thread, where an admin made a modified .ini file for the topic starter: l viewtopic.php?t=8368 l
    Would someone be able to do the same for me? Modifying the .ini file by hand returns in an signed file error, for me at least.
    Thanks in advance.
    eschwellinger - 2019-07-01
    on Windows 10 this inf tweecking is not possible anymore.
    Which Hardware ID has your network card?
    (Windows Device Manager)
    Hi Edwin,
    Thanks for your fast response! Codesys is indeed running in a Windows 10 environment.. That explains why it didn't work
    I'll get back to you asap with the hardware ID of the device as I haven't got access to the NUC right now.
    Thank you!
    Reno
  • LooijmansR - 2019-07-02
    Hi Edwin,
    As agreed hereby the Hardware IDs of the device.
    PCI\VEN_8086&DEV_15BE&SUBSYS_20748086&REV_30
    PCI\VEN_8086&DEV_15BE&CC_020000
    Thanks in advance.
    Kind regards,
    Reno
    eschwellinger - 2019-07-03
    I will send a testversion to check.
