PN-Controller not running
remco1271
2019-04-08
2021-01-23
  • remco1271 - 2019-04-08
    The profinet controller is not more running.
    I did try already a reinstall (with c:\ProgramData\CODESYS\ removed) but it did not change anything
    On startup i see the error "Controller Error: PNIO: LMPM signaled an error"
    01554726709186: Cmp=CM, Class=1, Error=0, Info=4, pszInfo= CODESYS Control V3 - 64Bit
    01554726709186: Cmp=CM, Class=1, Error=0, Info=5, pszInfo= Copyright (c) 3S - Smart Software Solutions GmbH
    01554726709186: Cmp=CM, Class=1, Error=0, Info=6, pszInfo= <version>3.5.14.10</version> <builddate>Feb 14 2019</builddate>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>CM</cmp>, <id>0x00000001</id> <ver>3.5.14.10</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>CmpMemPool</cmp>, <id>0x0000001e</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>CmpLog</cmp>, <id>0x00000013</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>CmpSettings</cmp>, <id>0x0000001a</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>SysFile</cmp>, <id>0x00000104</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>SysWindowFileDialog</cmp>, <id>0x0000011a</id> <ver>3.5.14.10</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>SysWindow</cmp>, <id>0x00000117</id> <ver>3.5.14.10</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>SysTimeRtc</cmp>, <id>0x00000127</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>SysTimer</cmp>, <id>0x00000116</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>SysTime</cmp>, <id>0x00000115</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>SysTask</cmp>, <id>0x00000114</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>SysTarget</cmp>, <id>0x00000112</id> <ver>3.5.14.10</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>SysSocket</cmp>, <id>0x00000111</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>SysShm</cmp>, <id>0x00000110</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>SysSemProcess</cmp>, <id>0x00000119</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>SysSemCount</cmp>, <id>0x00000139</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>SysSem</cmp>, <id>0x0000010f</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>SysProcess</cmp>, <id>0x0000010e</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>SysPort</cmp>, <id>0x0000010d</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>SysPci</cmp>, <id>0x0000010c</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>SysOut</cmp>, <id>0x0000010b</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>SysNativeControl</cmp>, <id>0x0000012f</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>SysNativeCommonControls</cmp>, <id>0x00000138</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>SysMutex</cmp>, <id>0x0000013a</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>SysMsgQ</cmp>, <id>0x0000010a</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>SysModule</cmp>, <id>0x00000109</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>SysMem</cmp>, <id>0x00000108</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>SysInternalLib</cmp>, <id>0x00000107</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>SysInt</cmp>, <id>0x00000106</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>SysGraphicGDIPlus</cmp>, <id>0x0000012a</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>SysFileStream</cmp>, <id>0x00000120</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>_</cmp>, <id>0x00000103</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>SysEvent</cmp>, <id>0x00000102</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>SysEthernet</cmp>, <id>0x0000011c</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>SysDir</cmp>, <id>0x0000011b</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>SysCpuHandling</cmp>, <id>0x00000101</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>SysCom</cmp>, <id>0x00000100</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>CmpMemGC</cmp>, <id>0x0000001f</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System: <cmp>CmpCodeMeter</cmp>, <id>0x0000007a</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System|Dynamic: <cmp>SysCpuMultiCore</cmp>, <id>0x0000013d</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System|Dynamic: <cmp>SysReadWriteLock</cmp>, <id>0x0000013e</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= System|Dynamic: <cmp>SysCpuBreakpoints</cmp>, <id>0x00000305</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpObjectMgr</cmp>, <id>0x00000080</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpXMLParser</cmp>, <id>0x00000058</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpVisuServer</cmp>, <id>0x00000057</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpVisuHandler</cmp>, <id>0x00000054</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpVisuClientControllerHost</cmp>, <id>0x00000132</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpUserMgr</cmp>, <id>0x00000061</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpUserDB</cmp>, <id>0x00000064</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpUserDBObjects</cmp>, <id>0x00000091</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpTraceMgr</cmp>, <id>0x00000070</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpSupervisor</cmp>, <id>0x0000008f</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpSrv</cmp>, <id>0x0000001c</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpSecurityManager</cmp>, <id>0x0000008e</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpSecureChannel</cmp>, <id>0x00000090</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpSchedule</cmp>, <id>0x00000019</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpRouter</cmp>, <id>0x00000018</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpRetain</cmp>, <id>0x00000017</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpPlcShell</cmp>, <id>0x00000128</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpOpenSSL</cmp>, <id>0x00000033</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpOPCUAStack</cmp>, <id>0x0000008d</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpOPCUAServer</cmp>, <id>0x00000124</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpOPCUAProviderIecVarAccess</cmp>, <id>0x00000126</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpNameServiceServer</cmp>, <id>0x00000016</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpNameServiceClientIec</cmp>, <id>0x0000011d</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpNameServiceClient</cmp>, <id>0x00000015</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpMonitor2</cmp>, <id>0x00000032</id> <ver>3.5.14.10</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpMonitor</cmp>, <id>0x00000014</id> <ver>3.5.14.10</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpIpc</cmp>, <id>0x0000001d</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpIoMgr</cmp>, <id>0x00000012</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpIoDrvIec</cmp>, <id>0x0000005a</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpIoDrvC</cmp>, <id>0x00000066</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpIecVarAccess</cmp>, <id>0x00000060</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpIecTask</cmp>, <id>0x00000011</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpIecStringUtils</cmp>, <id>0x0000007f</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpFileTransfer</cmp>, <id>0x0000005e</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpEventMgr</cmp>, <id>0x0000005b</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpDynamicText</cmp>, <id>0x00000051</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpDevice</cmp>, <id>0x0000000e</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpCryptMD5</cmp>, <id>0x0000006a</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpCoreDump</cmp>, <id>0x00000083</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpCommunicationLib</cmp>, <id>0x0000000c</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpChecksum</cmp>, <id>0x0000000b</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpChannelServer</cmp>, <id>0x0000000a</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpChannelMgr</cmp>, <id>0x00000009</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpChannelClientIec</cmp>, <id>0x0000005d</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpChannelClient</cmp>, <id>0x00000008</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpCAATypes</cmp>, <id>0x00004006</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpCAATimer</cmp>, <id>0x00004016</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpCAATickUtil</cmp>, <id>0x00004010</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpCAATick</cmp>, <id>0x00004009</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpCAAStorage</cmp>, <id>0x0000007e</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpCAASerialCom</cmp>, <id>0x00004012</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpCAASegBufferMan</cmp>, <id>0x00004019</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpCAASdoServer</cmp>, <id>0x00004017</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpCAASdoClient</cmp>, <id>0x00004011</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpCAARealTimeClock</cmp>, <id>0x00004014</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpCAANetBaseServices</cmp>, <id>0x00004018</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpCAAMemBlockMan</cmp>, <id>0x00004003</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpCAAFile</cmp>, <id>0x00004008</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpCAADTUtil</cmp>, <id>0x00004013</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpCAACanL2</cmp>, <id>0x00004004</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpCAACallback</cmp>, <id>0x00004001</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpCAABehaviourModel</cmp>, <id>0x00004015</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpCAAAsyncMan</cmp>, <id>0x00004007</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpBlkDrvUdp</cmp>, <id>0x00000007</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpBlkDrvTcp</cmp>, <id>0x00000030</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpBlkDrvShm</cmp>, <id>0x00000068</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpBlkDrvCom</cmp>, <id>0x00000006</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpBitmapPool</cmp>, <id>0x00000050</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpBinTagUtilIec</cmp>, <id>0x0000005c</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpBinTagUtil</cmp>, <id>0x00000004</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpAsyncMgr</cmp>, <id>0x0000005f</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpAppForce</cmp>, <id>0x00000074</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpAppBP</cmp>, <id>0x00000073</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpApp</cmp>, <id>0x00000002</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= <cmp>CmpAlarmManager</cmp>, <id>0x0000007c</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= Dynamic: <cmp>CmpTargetVisuStub</cmp>, <id>0x00000053</id> <ver>3.5.14.0</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= Dynamic: <cmp>CmpWebServer</cmp>, <id>0x00000071</id> <ver>3.5.14.10</ver>
    01554726709186: Cmp=CM, Class=1, Error=0, Info=10, pszInfo= Dynamic: <cmp>CmpWebServerHandlerV3</cmp>, <id>0x00000072</id> <ver>3.5.14.10</ver>
    01554726709222: Cmp=SysCpuMultiCore, Class=1, Error=0, Info=4, pszInfo= MultiCore support: [activated], all cores are used
    01554726709222: Cmp=SysCpuMultiCore, Class=1, Error=0, Info=4, pszInfo= Number of available cores: 4
    01554726709689: Cmp=CmpChannelServer, Class=1, Error=0, Info=0, pszInfo= <NumOfChannels>4</NumOfChannels> channels available, each of the size <BufferSize>100000</BufferSize> Bytes
    01554726709689: Cmp=CmpChannelMgr, Class=1, Error=0, Info=2, pszInfo= Running as network server
    01554726709689: Cmp=CmpChannelMgr, Class=1, Error=0, Info=1, pszInfo= Running as network client
    01554726709700: Cmp=CmpBlkDrvUdp, Class=1, Error=0, Info=6, pszInfo= Network interface: <ipaddress>192.168.1.126</ipaddress>, subnetmask <subnetmask>255.255.255.0</subnetmask>
    01554726709700: Cmp=CmpRouter, Class=1, Error=0, Info=4, pszInfo= Network interface <interface>ether 1</interface> at router <instance>0</instance> registered
    01554726709700: Cmp=CmpBlkDrvUdp, Class=1, Error=0, Info=6, pszInfo= Network interface: <ipaddress>192.168.1.174</ipaddress>, subnetmask <subnetmask>255.255.255.0</subnetmask>
    01554726709700: Cmp=CmpRouter, Class=1, Error=0, Info=4, pszInfo= Network interface <interface>ether 6</interface> at router <instance>1</instance> registered
    01554726710096: Cmp=CmpOPCUAServer, Class=1, Error=0, Info=0, pszInfo= No certificate for the OPC UA server available.
    01554726710096: Cmp=CmpOPCUAServer, Class=1, Error=0, Info=0, pszInfo= Security policy allows plain text communication. Secure communication is deactivated.
    01554726710109: Cmp=CmpOPCUAServer, Class=1, Error=0, Info=0, pszInfo= **************************************************************
    01554726710109: Cmp=CmpOPCUAServer, Class=1, Error=0, Info=0, pszInfo=     OPC UA Server Started:
    01554726710109: Cmp=CmpOPCUAServer, Class=1, Error=0, Info=0, pszInfo=     Hostname: localhost, Port: 4840
    01554726710109: Cmp=CmpOPCUAServer, Class=1, Error=0, Info=0, pszInfo=     URL: opc.tcp://localhost:4840
    01554726710109: Cmp=CmpOPCUAServer, Class=1, Error=0, Info=0, pszInfo=     Loopbackadapter activated.
    01554726710109: Cmp=CmpOPCUAServer, Class=1, Error=0, Info=0, pszInfo=     All available networkadapters are used.
    01554726710109: Cmp=CmpOPCUAServer, Class=1, Error=0, Info=0, pszInfo= Provider CODESYS_DefaultProvider with Version 0x3050e00 registerd at the OPC UA server.
    01554726710115: Cmp=CmpOPCUAServer, Class=1, Error=0, Info=0, pszInfo= Provider CmpOPCUAProviderIecVarAccess with Version 0x3050e00 registerd at the OPC UA server.
    01554726710139: Cmp=CmpBlkDrvTcp, Class=1, Error=0, Info=6, pszInfo= Local network address: <ipaddress>192.168.1.126</ipaddress>
    01554726710140: Cmp=CmpRouter, Class=1, Error=0, Info=4, pszInfo= Network interface <interface>BlkDrvTcp</interface> at router <instance>2</instance> registered
    01554726710142: Cmp=CmpRouter, Class=1, Error=0, Info=4, pszInfo= Network interface <interface>BlkDrvShm</interface> at router <instance>3</instance> registered
    01554726710142: Cmp=CmpBlkDrvShm, Class=1, Error=0, Info=9, pszInfo= Local address (BlkDrvShm) set to <address>1</address>
    01554726710233: Cmp=CmpRouter, Class=1, Error=0, Info=1, pszInfo= Setting router <instance>0</instance> address to <address>(007e)</address>
    01554726710233: Cmp=CmpRouter, Class=1, Error=0, Info=1, pszInfo= Setting router <instance>1</instance> address to <address>(00ae)</address>
    01554726710233: Cmp=CmpRouter, Class=1, Error=0, Info=1, pszInfo= Setting router <instance>2</instance> address to <address>(2ddc:c0a8:017e)</address>
    01554726710233: Cmp=CmpRouter, Class=1, Error=0, Info=1, pszInfo= Setting router <instance>3</instance> address to <address>(0001)</address>
    01554726710629: Cmp=SysCpuMultiCore, Class=1, Error=0, Info=4, pszInfo= Number of licensed cores for IEC-tasks: 1 from 4
    01554726710758: Cmp=IoDrvEthernet, Class=4, Error=0, Info=0, pszInfo=**** Setting IP Address and Subnetmask returned with Error Code 39
    01554726710758: Cmp=IoDrvEthernet, Class=4, Error=0, Info=0, pszInfo=**** Ethernet 2 is disabled for changing communication settings!
    01554726718991: Cmp=Profinet, Class=1, Error=0, Info=1, pszInfo= no remanent data  - use defaults
    01554726718991: Cmp=Profinet, Class=1, Error=0, Info=1, pszInfo= No valid remanent data.
    01554726718991: Cmp=Profinet, Class=1, Error=0, Info=1, pszInfo= Init Device: StationName = controller
    01554726718991: Cmp=Profinet, Class=1, Error=0, Info=1, pszInfo= Init Device: IP = 192.168.1.126 / 255.255.255.0 / 192.168.1.1
    01554726721339: Cmp=IoDrvEthernet, Class=4, Error=0, Info=0, pszInfo=**** Setting IP Address and Subnetmask returned with Error Code 39
    01554726721402: Cmp=CmpOPCUAProviderIecVarAccess, Class=1, Error=0, Info=0, pszInfo= Valid license found for OPC UA IecVarAccess provider.
    01554726721481: Cmp=CmpApp, Class=1, Error=0, Info=22, pszInfo= No retain area in bootproject of application [<app>Application</app>]
    01554726721482: Cmp=CmpApp, Class=1, Error=0, Info=6, pszInfo= Bootproject of application [<app>Application</app>] loaded
    01554726721486: Cmp=CmpApp, Class=1, Error=0, Info=10, pszInfo= Application [<app>Application</app>] started
    01554726721486: Cmp=CM, Class=1, Error=0, Info=34, pszInfo= CODESYS Control ready
    01554726721539: Cmp=IECVisualization, Class=1, Error=0, Info=0, pszInfo= Visuinitialization starting.
    01554726721541: Cmp=IECVisualization, Class=1, Error=0, Info=0, pszInfo= Visuinitialization done.
    01554726721542: Cmp=CmpWebServer, Class=1, Error=0, Info=0, pszInfo= **************************************************************
    01554726721542: Cmp=CmpWebServer, Class=1, Error=0, Info=0, pszInfo=                    Web Server
    01554726721542: Cmp=CmpWebServer, Class=1, Error=0, Info=0, pszInfo=       Root directory : $PlcLogic$/$visu$
    01554726721542: Cmp=CmpWebServer, Class=1, Error=0, Info=0, pszInfo=       Host :       localhost
    01554726721542: Cmp=CmpWebServer, Class=1, Error=0, Info=0, pszInfo=       HTTP port  : 8080
    01554726721542: Cmp=CmpWebServer, Class=1, Error=0, Info=0, pszInfo=       HTTPS port : 443
    01554726721542: Cmp=CmpWebServer, Class=1, Error=0, Info=0, pszInfo=       Connection type : HTTP, HTTPS
    01554726721543: Cmp=CmpOpenSSL, Class=1, Error=0, Info=0, pszInfo= TlsCreateContext: The given namespace 'WebServer' was not found in config file.
    01554726721543: Cmp=CmpWebServer, Class=1, Error=0, Info=0, pszInfo= The needed certificate is not available for HTTPS.
    01554726721543: Cmp=CmpWebServer, Class=1, Error=0, Info=0, pszInfo= HTTPS is not working with your configuration. See previous log entries for details!
    01554726722819: Cmp=IoDrvEthernet, Class=1, Error=0, Info=0, pszInfo= Ethernet 2 successfully opened with IP: 192.168.1.126 and Subnetmask: 255.255.25
    01554726723804: Cmp=CM, Class=2, Error=0, Info=0, pszInfo=!!!! CODESYS Control Service: DEMO mode activated, terminating in approx. 120 minutes.
    01554726723949: Cmp=CmpRouter, Class=1, Error=0, Info=1, pszInfo= Setting router <instance>3</instance> address to <address>(037e:0001)</address>
    01554726726287: Cmp=Profinet, Class=4, Error=1, Info=1, pszInfo=**** Controller Error: PNIO: LMPM signaled an error
    01554726776374: Cmp=IECVisualization, Class=1, Error=0, Info=0, pszInfo= Visu_PRG: Creating Client for Extern-ID: 798076
    01554726776374: Cmp=OnlineLicenseManager, Class=4, Error=0, Info=0, pszInfo=**** License for TargetVisualization not installed.
    01554726776392: Cmp=IECVisualization, Class=1, Error=0, Info=0, pszInfo= Visu_PRG: Creating Client successful for Extern-ID: 798076 Returned IEC-ID: 0
    eschwellinger - 2019-04-08
    hi,
    things to check:
    1. WinPCAP is installed
    2. How many network adapters does your system have ( should not be more than 6) if more disable some of them..
    3. Disable Firewall for the fist tests
    Then in your project you have enabled to set the IP of the network which you want to use for profinet.
    This need to be enabled by a setting in the config file
    [SysSocket]
    Adapter.0.Name="ethernet" //this is the name which you see under windows for your network
    Adapter.0.EnableSetIpAndMask=1
  • remco1271 - 2019-04-09
    Thank you it did work.
    Bluetooth did make one more network adapter, disabled it and now it is working again
  • trent1234 - 2021-01-22
    Hello, I am having the same issue. Where is the Config file you are mentioning?
    eschwellinger - 2021-01-23
    For Control Win plc:
    c:\ProgramData\CODESYS\CODESYSControlWinV3x64\xxxxxx\CODESYSControl.cfg
