Unresolved Reference: "CODEMGETCONTENTBYFIRMCODE2"
francke
2018-10-29
2021-04-13
  • francke - 2018-10-29
    I'm using a Codesys RTE V3.5.9.40 for as my controller and when I am trying to download a program from my local PC I receive the error following error:
    When I open the PLC configuration for diagnostics, the logger shows up the following message:
    I have checked that all versions are compatible in the Development environment and the Soft-PLC as well as the libraries versions, but still this error shows up. Any ideas?
    Thanks,
    Alan.
    IMG: Unresolved Ref. Error 2.PNG
    IMG: Unresolved Ref. Error.PNG
  • eschwellinger
    eschwellinger - 2018-10-30
    seems that the codemeter component is missing in the CODESYSControl.cfg of your Control RTE.
  • francke - 2018-10-30
    Thanks alot for your reply. I realized that when I installed the RTE on my machine, I removed the CodeMeter feature at install, I wasn't sure exactly if I would need it.
    I reinstalled Codesys and made sure to leave this feature on, an it solved the issue.
    Regards,
    Alan.
    IMG: CodeMeter.PNG
  • jrenner - 2019-05-24
    I am using E!cockpit from wago and it uses Codesys 3.5. I have the same error. How do I fix that with E!cockpit?
    • codesysuser - 2020-09-23
      Hello, Did you find solution for this problem. I have the same issue
      Best regards
      Anton
  • eschwellinger
    eschwellinger - 2019-05-27
    please ask the Wago support for advice.
  • trof - 2021-04-13
    Hi, I had the same error in eCockpit v1.8.0.2 After a couple reinstalls of the software decided to change the placeholder of CmpCodeMeter in the library manager (from 3.5.5 to 3.5.2) and that did the trick.
    Cheers
    Teodor
