It is currently Mon Feb 18, 2019 2:48 am
PostPosted: Thu Oct 04, 2018 11:55 am
Is there any plans for Codesys3 support for the 750-8207 with integrated 3G-modem/mobile radio module ?
Its not on the list of supported devices.
If it is/will be supported, does it, and the other models in the PFC200 series, support profinet master?
It doesnt seem to be the case if programming through wagos own programming environment.
We are currently controlling servo amplifiers through CANopen, but would like to use profinet or ethercat instead.
Got an answer from Wago´s automation support that the controllers are´nt powerful enough for these fieldbuses.
PostPosted: Thu Oct 04, 2018 12:54 pm
If you using wago PLC and running CODESYS Control for PFC200 SL then you can enjoy profinet (master or slave) or ethercat(master only). I have done few project where using this combination for ethercat purpose.
PostPosted: Thu Oct 04, 2018 1:01 pm
Excellent! Thanks.
I guess the PFC200 SL will run on the 750-8207 aswell, but how about support for the Mobile radio module / 3G-GSM module ?
If not available in Codesys, is it still available in the linux os ?
PostPosted: Thu Oct 04, 2018 2:03 pm
should work, ( sure depends on what you exactly expect)
the sms product is supported to work with the device 750-8207
https://store.codesys.com/sms-service.html#System Requirements
We have no special library to work with the GSM either Linux commands or at commands via serial are neededto use with this.
