It is currently Sun May 19, 2019 7:41 am
PostPosted: Wed Aug 08, 2018 2:26 am
Version : OPCDEMO , 3.5.12.0 in store
WIN SL : CODESYS V3.5 SP13 + (64BIT) , DEMO
OS : Windows 7, x64 bit
the same error (opc_config1_error) occured when setup like picture (opc_config1, opc_config2)
When connect the cdoesys opc server ,error message showed below
-CodeMeter 101597:8772
Failre reason : CmContainer Entry not FOund , Error 200
-CodeMeterAct 5000304:8772
Failure reason : CmContainer Entry not Found , Error 200
PostPosted: Thu Aug 09, 2018 4:12 pm
either a demo license for OPC DA :
https://store.codesys.com/codesys-opc-da-server-sl.html
or a full OPC DA Server llicense is needed.
https://store.codesys.com/codesys-opc-d ... -demo.html
But to be honest take into account to use OPC UA this is embedded (OPC UA Server) too in the runtime - and is even licensed.
PostPosted: Tue Dec 04, 2018 10:34 am
How do you get the license from the store?
I only found the program there that Cheol Hong Kim is already using.
and where do you insert that license afterwards?
PostPosted: Wed Mar 20, 2019 8:15 am
Hello Edwin,
I have the same problem with the OPC DA like Cheol Hong Kim.
The links you have posted are not working.
How I get the demo license from the online store?
Best regards
ps. We use OPC UA but for the old plants we need also OPC DA
PostPosted: Wed Mar 20, 2019 9:36 am
yes sorry you are right,
here the new links:
https://store.codesys.com/codesys-opc-d ... undle.html
PostPosted: Wed Mar 20, 2019 3:34 pm
Hello Edwin,
Unfortunately it does not work.
The whole CODESYS 64 3.5.14.10 and CODESYS OPC DA Server 3.5.14.0 have been
uninstalled and installed several times on Windows 7 and 10 without success.
Still the same error message.
I would ask you for another suggestion how I can solve this problem.
Best regards
PostPosted: Wed Mar 20, 2019 5:11 pm
If you order this demo product ( free of charge) you will get a ticket number ( by mail you get the ticket or you should find it in your store account) which you need to activate for example by license.codesys.com on this device which is running the OPC DA server.
That should solve the issue.
PostPosted: Thu Mar 21, 2019 9:26 am
Hello Edwin,
It works.
Thank you.
Best regards.
