It is currently Mon May 20, 2019 12:23 pm
PostPosted: Tue Mar 13, 2018 8:12 am
I am trying to control Omron G5 (R88D-KN01-ECT) in Torque mode.
I use Codesys V3.5.12 and Codesys RTE 3.5.12.0 Softmotion in Windows 10.
To control in Torque mode, as Omron G5 manual, I must change PDO mapping as: use #1704 for output,
use #1B02 for input.
Then I also add to Startup Parameter: 60E0( positive torque limit value) , 60E1(negative torque limit value), 607F (Max profile velocity), 6060 (Op Mode).
After setting, I use SMC_SetTorque to control torque, but the actual torque is not change (keep 0).
I don't know why I can not control Torque.
Can anyone help me to solve this problem.
I also attached my project and source.
Thanks
Nguyen akv
PostPosted: Tue Mar 13, 2018 6:26 pm
remove the MainTask...
PostPosted: Wed Mar 14, 2018 7:28 am
Hi Edwin,
I tried to remove Main_Task as you guide.
But I can not to control torque.
Can you give me any suggestion and ideal to control in Torque Mode with Omron G5?
I see that ESI file(.xml) of Omron G5 is newer than ESI file (.xml) of Codesys make for Omron G5.
As I understand, Codesys use "ESI_Omron_R88D-KNxxx-ECT_Ver2_0_rev09.xml.
But Omron servo Drive will use "Omron R88D-KNxxx-ECT.xml".
What do you think about the difference of that?
Because I can control normally in Position Mode, but when change PDO mapping to Torque mode
I can not control torque.
Thanks,
Nguyen AKV
