It is currently Sat Apr 20, 2019 1:17 pm
PostPosted: Wed Jan 31, 2018 5:00 am
I am currently using CoDeSys V3.5 SP12 trying to grab drab some sensor data using a controller. Let me touch on the hardware architecture first.
Computer -> LAN cable -> Conprosys controller -> RS-232 Serial cable -> CHINO temperature senor
I have seen guides on how to open serial com ports using "COM.Open" and such but they are focusing on Computer -> Serial -> Controller. In my case I am hoping to open the Controller SERIAL COM port. I searched for the data sheet and it indicated that the CoDeSys syntax for that controller serial com port being "PORT 1"
Link to mentioned controller (CPS-PCS341MB-DS1-1201): https://www.contec.com/jp/download/cont ... 370d53120a
So how do I actually go about activating that Serial com port on the controller in CoDeSys?
Another issue being more of CoDeSys.
When I add Devices in CoDeSys, which do I select for my LAN then Serial configuration?
MODBUS_COM> MODBUS_SERIAL_DEVICE
or
MODBUS_COM> MODBUS_MASTER_COM_PORT> MODBUS_SLAVE_COM_PORT
or
Ethernet> MODBUSTCP_SLAVE_DEVICE
This has been confusing me for quite some time now, have no background on CoDeSys. Appreciate any help and confirmation, thanks.
PostPosted: Wed Jan 31, 2018 9:23 am
which plc are you using, is this Control Win?
I would recommend to the check this examples here:
https://store.codesys.com/serial-com.html
->install it via CODESYS shopping cart and open it then here
'c:\Users\<YourWindowsUserName>\CODESYS Examples\SerialCom\1.0.0.1\SerialCom.project
There are two applications in you need to decide which one is better for your needs (SyscomExample is more low Level based on the syslibs)
If you see the project, there is nothing in the device tree according the Serial communcation... so for plain using the com port
this is not needed.
If you use a higher level protocoll like modbus rtu, then you need to add a modbus serial com port.
PostPosted: Thu Aug 30, 2018 8:52 am
Hello everybody,
I try to execute the SerialCom.project example on my PC (simulation mode) with an USB serial adapter to emulate a COM1 but the opening never work.
The handler is always 16#0! (see below)
I try too on a target but the trouble is the same, handler never found...
Kind regard,
Thomas.
PostPosted: Thu Aug 30, 2018 3:28 pm
this does not work in simulation mode,
please start Control WIN in your Task tray - and login to this plc on your pc -
then this will work.
PostPosted: Thu Aug 30, 2018 4:57 pm
Quote:
Thank you Edwin for your help.
I start on Control WIN but the handler is always never found...(see below):
PostPosted: Fri Aug 31, 2018 3:09 pm
Thom wrote:
Quote:
After many try, I delete all test of the handler value and force to write on the serial port and data are correctly sent...
So, I don't understand what is the problem with the handler but it seems it not correctly fill.
NB: Version of Codesys used is V3.5.13.0.
Regards.
