the controller device is not registered softmotion device
Anonymous
2017-12-11
2021-05-17
  • Anonymous - 2017-12-11
    Originally created by: eser_
    Hello everyone,
    I am trying to control metronix servo via codesys win v3.
    But when i login there is as 'the controller device is not registered softmotion device'.
    What this mean and how can i solve this problem.
    can anyone help.
    Thank you.
    IMG: screen
    IMG: screen
  • acasilla - 2020-10-26
    Did you resolve theses error?
  • eschwellinger
    eschwellinger - 2020-10-27
    you need to select a device which is capable for SoftMotion, that's the solution for this.
  • marla - 2021-03-15
    I am facing the same problem. Due to the fact I am using a Delta ASDA-A2-E Controller, it should be capabale for SoftMotion, right?
    I installed SM3_Basic and SM3_Drive_ETC_Delta_ASDA_A2 libraries and the Ethercat bus is working when writing onto the ControlWord manually. But I still get this error and am not able to use any SoftMotion functions. Could you please tell me what I might be missing out on here?
    Last edit: marla 2021-03-15
    • acasilla - 2021-03-15
      You need install the licence.
      You need check if you device suport softmotion and if you device suport softmotion buy the licence and install, I think the cost is 120 usd or something like that.
  • marla - 2021-03-16
    Thanks for the quick reply. I already got the SoftMotion license and installed it on my device. In the CodeSys homepage it says that Delta ASDA A2 is a supported device, so this should not be the problem I guess.
    Are there any other licenses needed? Or any other libraries?
    Ok, nevermind. I was suspecting the wrong device to be the problem. My PLC PFC200 is not compatible with SoftMotion. In case someone runs into the same error...
  • eschwellinger
    eschwellinger - 2021-03-17
    ..the upcoming version 4.1.0.0 on runtime side and CODESYS SP17 release, every device is basically capabale for SoftMotion. ( sure if the device OS fullfill the reatime capabilities)
    Last edit: eschwellinger 2021-03-17
  • marla - 2021-03-17
    Thanks for the info. Do you already know when these will be available?
  • eschwellinger
    release on 29th march
  • acasilla - 2021-05-13
    The new version was relase, the sp17 resolve the problem?
  • marla - 2021-05-17
    I put my CodeSys project aside and used another PLC for the project, so that I can't tell. When using the PFC PLC in some future project I will try again...
