I have done a VBScript that works if I launch it by prompt, but if I try to start the script from code I can see wscript.exe starts but looks like that the execution is blocked.
Using Codesys 3.5 SP9 Patch8, I have tryed SysProcess library 3.5.7.0 and SyOS23 3.5.8.0 library but each time I can see that starts wscript.exe but is not executed the code inside the script (using the prompt works, so the vbs script is ok).
stop the plc by tasktray, then execute the Control Win in debug mode:
c:\Program Files (x86)\3S CODESYS\GatewayPLC\CODESYSControlService.exe -d
check the the log there if you execute your script
I have done this procedure, and I don't know why, but if I keep the service in debug mode the script works.
Whitout the "-d" parameter the service doesn't work
Launching the script in debug mode doesn't generate any verbose message on debug panel.
which plc are you using?
Guess an entry in CODESYSControl.cfg
[SysProcess]
Command.0=xxxxx
is probably needed.
Thanks for replay,
I am using a Codesys Control Win V3 on a PC
On CODESYSControl.cfg I have this:
Any Suggestion?
I would try:
and check the reaturn value.
using the "SysProcess._" function I got 1 as Result
and copy your script which you want to execute to the runtime directory.
I have attached the vbscript that I want to execute (I have modified the extension from .vbs to .txt due to forum restriction)
SendMailCopy.txt [2.61 KiB]
