retain variables emPC-A/iMX6 SL
AlexD
2017-10-11
2017-10-11
  • AlexD - 2017-10-11
    retain variables are set to zero after reboot
    /data/etc/CODESYSControl_User.cfg
    [CmpApp]
    Bootproject.RetainMismatch.Init=1
    RetainType.Applications=InSRAM
    /data/etc/CODESYSControl.cfg
    ; Note!!!
    ; Don't edit this file, as changes on this file will be
    ; lost after reboot, if the system is running in read-only mode.
    ; Please use /data/etc/CODESYSControl_User.cfg instead.
    [ComponentManager]
    Component.1=SysGraphic
    Component.2=SysWindow
    Component.3=SysNativeControl
    [SysFile]
    FilePath.1=/etc/, 3S.dat
    PlcLogicPrefix=1
    [CmpSocketCanDrv]
    ScriptPath=/opt/codesys/scripts/
    ScriptName=rts_set_baud.sh
    [CmpSettings]
    FileReference.0=SysFileMap.cfg, SysFileMap
    FileReference.1=/data/etc/CODESYSControl_User.cfg
    [_]
    Linux.DisableFpuUnderflowException=1
    Linux.DisableFpuOverflowException=1
    Linux.DisableFpuInvalidOperationException=1
    [CmpRetain]
    Retain.SRAM.Size=0x20000
    Retain.SRAM.Address=0x08000000
    [SysProcess]
    Command.0=shutdown
    [CmpWebServer]
    ConnectionType=0
    [CmpOpenSSL]
    WebServer.Cert=server.cer
    WebServer.PrivateKey=server.key
    WebServer.CipherList=HIGH
    [CmpLog]
    Logger.0.Name=/tmp/codesyscontrol.log
    Logger.0.Filter=0x0000000F
    Logger.0.Enable=1
    Logger.0.MaxEntries=1000
    Logger.0.MaxFileSize=1000000
    Logger.0.MaxFiles=1
    Logger.0.Backend.0.ClassId=0x00000104 ;writes logger messages in a file
    Logger.0.Type=0x314 ;Set the timestamp to RTC
    [SysMem]
    Linux.Memlock=0
    [CmpCodeMeter]
    InitLicenseFile.0=3SLicense.wbb
    [SysEthernet]
    Linux.ProtocolFilter=3
    [CmpSchedule]
    SchedulerInterval=4000
    ProcessorLoad.Enable=1
    ProcessorLoad.Maximum=95
    ProcessorLoad.Interval=5000
    [SysCom]
    Linux.Devicefile=/dev/ttymxc
    [CmpApp]
    Application.1=Application
    emPC-A/iMX6Q/2 SY-EPC-64002
    codesys control 3.5.11.20
    please help i cant understand what i did wrong.
    i had another project with first version of emPC-imx6 control on SY-EPC-64001 where everything works fine.
    when i tried to install i received an error "/data/CODESYSControl.cfg missing..", after installed again through codesys no error,
    i saw that config files are different in another janz i have CODESYSControl_User_Default.cfg which is not referenced in CODESYSControl.cfg
    Problem solved! it seems was some user rights issues with the new janz image, no write rights with user dev on home folder and maybe others... i'm not linux expert .
    edited /data/etc/CODESYSControl_User.cfg as root, /data/etc/ container for root?????
    [CmpApp]
    removed /data/etc/CODESYSControl_User.cfg ???? /data/etc/ container for dev????
