/data/etc/CODESYSControl.cfg
; Note!!!
; Don't edit this file, as changes on this file will be
; lost after reboot, if the system is running in read-only mode.
; Please use /data/etc/CODESYSControl_User.cfg instead.
[CmpLog]
Logger.0.Name=/tmp/codesyscontrol.log
Logger.0.Filter=0x0000000F
Logger.0.Enable=1
Logger.0.MaxEntries=1000
Logger.0.MaxFileSize=1000000
Logger.0.MaxFiles=1
Logger.0.Backend.0.ClassId=0x00000104 ;writes logger messages in a file
Logger.0.Type=0x314 ;Set the timestamp to RTC
emPC-A/iMX6Q/2 SY-EPC-64002
codesys control 3.5.11.20
please help i cant understand what i did wrong.
i had another project with first version of emPC-imx6 control on SY-EPC-64001 where everything works fine.
when i tried to install i received an error "/data/CODESYSControl.cfg missing..", after installed again through codesys no error,
i saw that config files are different in another janz i have CODESYSControl_User_Default.cfg which is not referenced in CODESYSControl.cfg
Problem solved! it seems was some user rights issues with the new janz image, no write rights with user dev on home folder and maybe others... i'm not linux expert .
edited /data/etc/CODESYSControl_User.cfg as root, /data/etc/ container for root????? [CmpApp]
Bootproject.RetainMismatch.Init=1
RetainType.Applications=InSRAM
Application.1=Application
removed /data/etc/CODESYSControl_User.cfg ???? /data/etc/ container for dev????
retain variables are set to zero after reboot
[CmpApp]
; Note!!!
[ComponentManager]
Component.1=SysGraphic
Component.2=SysWindow
Component.3=SysNativeControl
[SysFile]
FilePath.1=/etc/, 3S.dat
PlcLogicPrefix=1
[CmpSocketCanDrv]
ScriptPath=/opt/codesys/scripts/
ScriptName=rts_set_baud.sh
[CmpSettings]
FileReference.0=SysFileMap.cfg, SysFileMap
FileReference.1=/data/etc/CODESYSControl_User.cfg
[_]
Linux.DisableFpuUnderflowException=1
Linux.DisableFpuOverflowException=1
Linux.DisableFpuInvalidOperationException=1
[CmpRetain]
Retain.SRAM.Size=0x20000
Retain.SRAM.Address=0x08000000
[SysProcess]
Command.0=shutdown
[CmpWebServer]
ConnectionType=0
[CmpOpenSSL]
WebServer.Cert=server.cer
WebServer.PrivateKey=server.key
WebServer.CipherList=HIGH
[CmpLog]
Logger.0.Enable=1
Logger.0.MaxFiles=1
[SysMem]
Linux.Memlock=0
[CmpCodeMeter]
InitLicenseFile.0=3SLicense.wbb
[SysEthernet]
Linux.ProtocolFilter=3
[CmpSchedule]
SchedulerInterval=4000
ProcessorLoad.Enable=1
ProcessorLoad.Maximum=95
ProcessorLoad.Interval=5000
[SysCom]
Linux.Devicefile=/dev/ttymxc
[CmpApp]
[CmpApp]
