It is currently Wed Jan 16, 2019 10:51 am
PostPosted: Wed Oct 11, 2017 9:43 am
retain variables are set to zero after reboot :(
/data/etc/CODESYSControl_User.cfg
[CmpApp]
Bootproject.RetainMismatch.Init=1
RetainType.Applications=InSRAM
/data/etc/CODESYSControl.cfg
; Note!!!
; Don't edit this file, as changes on this file will be
; lost after reboot, if the system is running in read-only mode.
; Please use /data/etc/CODESYSControl_User.cfg instead.
[ComponentManager]
Component.1=SysGraphic
Component.2=SysWindow
Component.3=SysNativeControl
[SysFile]
FilePath.1=/etc/, 3S.dat
PlcLogicPrefix=1
[CmpSocketCanDrv]
ScriptPath=/opt/codesys/scripts/
ScriptName=rts_set_baud.sh
[CmpSettings]
FileReference.0=SysFileMap.cfg, SysFileMap
FileReference.1=/data/etc/CODESYSControl_User.cfg
[_]
Linux.DisableFpuUnderflowException=1
Linux.DisableFpuOverflowException=1
Linux.DisableFpuInvalidOperationException=1
[CmpRetain]
Retain.SRAM.Size=0x20000
Retain.SRAM.Address=0x08000000
[SysProcess]
Command.0=shutdown
[CmpWebServer]
ConnectionType=0
[CmpOpenSSL]
WebServer.Cert=server.cer
WebServer.PrivateKey=server.key
WebServer.CipherList=HIGH
[CmpLog]
Logger.0.Name=/tmp/codesyscontrol.log
Logger.0.Filter=0x0000000F
Logger.0.Enable=1
Logger.0.MaxEntries=1000
Logger.0.MaxFileSize=1000000
Logger.0.MaxFiles=1
Logger.0.Backend.0.ClassId=0x00000104 ;writes logger messages in a file
Logger.0.Type=0x314 ;Set the timestamp to RTC
[SysMem]
Linux.Memlock=0
[CmpCodeMeter]
InitLicenseFile.0=3SLicense.wbb
[SysEthernet]
Linux.ProtocolFilter=3
[CmpSchedule]
SchedulerInterval=4000
ProcessorLoad.Enable=1
ProcessorLoad.Maximum=95
ProcessorLoad.Interval=5000
[SysCom]
Linux.Devicefile=/dev/ttymxc
[CmpApp]
Application.1=Application
PostPosted: Wed Oct 11, 2017 12:53 pm
emPC-A/iMX6Q/2 SY-EPC-64002
codesys control 3.5.11.20
please help i cant understand what i did wrong.
i had another project with first version of emPC-imx6 control on SY-EPC-64001 where everything works fine.
when i tried to install i received an error "/data/CODESYSControl.cfg missing..", after installed again through codesys no error,
i saw that config files are different in another janz i have CODESYSControl_User_Default.cfg which is not referenced in CODESYSControl.cfg
PostPosted: Wed Oct 11, 2017 4:47 pm
Problem solved! it seems was some user rights issues with the new janz image, no write rights with user dev on home folder and maybe others... i'm not linux expert .
edited /data/etc/CODESYSControl_User.cfg as root, /data/etc/ container for root?????
[CmpApp]
removed /data/etc/CODESYSControl_User.cfg ???? /data/etc/ container for dev????
