It is currently Thu Jan 24, 2019 1:50 am
PostPosted: Mon Sep 25, 2017 8:58 am
Hi!
I am trying to write "a;" to a csv file, but the results is the picture below.
I think this is a bug. I have posted my code here. If you want to try this code. You can replace this code line
sFileName := Standard.CONCAT(sFileName, '.csv'); // <-- Change fileName here if you want to try
Whith your file location.
If I use this code
[code]sendText := STANDARD.CONCAT('a', ';'); // <-- Why does this not working?[/code]
it will not working for me. But if I use
sendText :='a;'.
It works perfect. Why? It is the same if I set the code as
sendText := SQL_Array_Text[i];
I get garbarge values too. Why?
PROGRAM SparaDataTillSQL
VAR
        xFileStdInit:       BOOL:=FALSE;
        uiFileStdState:     UINT:=0;
        sFileName:          CAA.FILENAME;
        hFile:              CAA.HANDLE;
        szFileSize1:        CAA.SIZE := 0;
        szFileSize2:        CAA.SIZE := 0;
        filop:              FILE.Open;
        filwr:              FILE.Write;
        filrd:              FILE.Read;
        filcl:              FILE.Close;
        filsp:              FILE.SetPos;
      Date_and_time_format: DATE_AND_TIME;
      datumNamn: STRING;
      SQL_Array_Text: ARRAY[0..1024] OF STRING;
      // Räknare
      i: INT;
   // Texten som skall skickas
   sendText: STRING;
END_VAR
IF NOT xFileStdInit THEN
   filop(xExecute:=FALSE);
    filcl(xExecute:=FALSE);
    filwr(xExecute:=FALSE);
    //filrd(xExecute:=FALSE);
   xFileStdInit:=TRUE;
    uiFileStdState:=0;
   //Skapa filnamn
   datumNamn := DT_TO_STRING(Date_and_time_format);
   datumNamn := STANDARD.REPLACE(datumNamn,'_', 1, 17); // Här tar vi bort :
   datumNamn := STANDARD.REPLACE(datumNamn,'CC', 1, 20); // Samma här också.
   sFileName := Standard.CONCAT('\FlashDrive\Project\Project Files\Reports\FTP_Get\',datumNamn);
   // Skapa en lång array med värden som skall loggas
   SQL_Array_Text[0] := GVL.Ordernummer;
   SQL_Array_Text[1] := GVL.VentilNamn;
   SQL_Array_Text[2] := GVL.SerieNummer;
   SQL_Array_Text[3] := GVL.VentilPort;
   SQL_Array_Text[4] := INT_TO_STRING(GVL.TestNummer);
   SQL_Array_Text[5] := GVL.FlodesInstallning;
   SQL_Array_Text[6] := GVL.TryckInstallning;
   SQL_Array_Text[7] := GVL.LastInstallning;
   SQL_Array_Text[8] := GVL.Operator;
   SQL_Array_Text[9] := INT_TO_STRING(GVL.MaxFlode);
   SQL_Array_Text[10] := GVL.VentilTyp;
   SQL_Array_Text[11] := BOOL_TO_STRING(GVL.Externt_Lackage);
   SQL_Array_Text[12] := BOOL_TO_STRING(GVL.Hysterestest);
   SQL_Array_Text[13] := LREAL_TO_STRING(GVL.Hysteresvarde);
   SQL_Array_Text[14] := BOOL_TO_STRING(GVL.Shuntslidkarvning);
   SQL_Array_Text[15] := REAL_TO_STRING(GVL.Shuntslidkarvningvarde);
   SQL_Array_Text[16] := BOOL_TO_STRING(GVL.Backventillackage);
   SQL_Array_Text[17] := REAL_TO_STRING(GVL.Backventillackagevarde);
   SQL_Array_Text[18] := BOOL_TO_STRING(GVL.Slidlackage);
   SQL_Array_Text[19] := REAL_TO_STRING(GVL.Slidlackagevarde);
   SQL_Array_Text[20] := BOOL_TO_STRING(GVL.Shuntlackage);
   SQL_Array_Text[21] := REAL_TO_STRING(GVL.ShuntlackageVarde);
ELSE
    CASE uiFileStdState OF
        0:(* create a new file *)
            filop.sFileName:=sFileName;
            filop.eFileMode:=FILE.MODE.MRDWR;
            filop.xExclusive:=TRUE;
            filop( xExecute:=TRUE);
            IF filop.xDone THEN
                hFile:=filop.hFile;
                uiFileStdState:=1;
            END_IF
            IF filop.xError THEN
                (* error handling*)
            END_IF
        1:(* write text in the file *)
            filwr.hFile:=hFile;
            filwr.pBuffer:=ADR('#,');
            szFileSize1:=SIZEOF('#,');
            filwr.szSize:=szFileSize1;
            filwr.udiTimeOut:=100000;    (* 100ms Timeout *)
            filwr( xExecute:=TRUE);
            IF filwr.xDone THEN
                uiFileStdState:=4;
            END_IF
            IF filwr.xError THEN
                (* error handling*)
            END_IF
        4:(* close file  - TestFile.txt *)
            filcl.hFile:=hFile;
            filcl( xExecute:=TRUE);
            IF filcl.xDone THEN
                uiFileStdState:=5;
            END_IF
            IF filcl.xError THEN
                (* error handling*)
            END_IF
        5: (* Open - Append mode *)
            filop.eFileMode:=FILE.MODE.MAPPD;
            IF filop.xDone THEN
                hFile:=filop.hFile;
                uiFileStdState:=6;
            END_IF
                (* error handling*)
            END_IF
      6:(* write text in the file *)
            filwr.hFile:=hFile;
            filwr.pBuffer:=ADR(sendText);
            szFileSize1:=SIZEOF(sendText);
            IF filwr.xDone THEN
                IF( i < 20) THEN
               i := i + 1;
            ELSE
               uiFileStdState:=8;
            END_IF
            END_IF
                (* error handling*)
            END_IF
      8:(* close file  - TestFile.txt *)
            filcl.hFile:=hFile;
            IF filcl.xDone THEN
                uiFileStdState:=9;
            //i := 0;
            END_IF
                (* error handling*)
            END_IF
      9: (* Nothing *)
    END_CASE
END_IF
PostPosted: Mon Sep 25, 2017 12:18 pm
Hello!
I found the solution to this problem!
Insted of
szFileSize1:= SIZEOF(sendText);
Use
szFileSize1:= INT_TO_UINT(STANDARD.LEN(sendText));
Moderator need to report this so the online help shows correct example.
