It is currently Wed Jan 16, 2019 11:15 am
PostPosted: Thu Sep 21, 2017 2:59 pm
Hello!
I have a problem. I want to write text to a file but cannot use the SysFile library. I have that included in my project, but RTS_IEC_HANDLE is not defined. Why?
My goal is to write to a MS SQL database, but I don't know how to do that, so I create a file insted and later a MS SQL database is going to pick up that file.
I'm using Codesys 3.5 SP8.
PostPosted: Thu Sep 21, 2017 6:34 pm
Have you tried adding the namespace before the type like:
SysOpenFile: SysFile.SysTypes.RTS_IEC_HANDLE;
njkk: SysFile.ACCESS_MODE;
PostPosted: Thu Sep 21, 2017 8:13 pm
No. I will try that tomorrow. I give you a reply then.
PostPosted: Fri Sep 22, 2017 6:49 am
No that doesn't work.
PostPosted: Fri Sep 22, 2017 7:16 am
I change library.
