Profinet Device IP set
steven85
2017-08-29
2017-09-06
  • steven85 - 2017-08-29
    Hi
    My name is Steven.OH
    I’m using Profinet Device (Ethernet) on My codesys RTE(x86).
    I have a question.
    I want to Set IP of my Codesys RET using external tool.
    How can I change IP without change of my Project?
    If I use this function, do I need change PNdevice.data ?
    Where is PNDevice.Data?
    Can I change the file ?
    My Environment
     Windows embedded standard 7
     Codesys RTE 3.5.11
    Thanks a lot for your great help.
    Best Regards.
  • eschwellinger
    eschwellinger - 2017-09-06
    there are some open points which are open to implement to make
    this possible.
    At the moment you need to set it manually.
    There is achance to have it on for SP12 release.
