It is currently Tue Mar 19, 2019 6:22 pm
 Post subject: Problem
PostPosted: Sat Jul 22, 2017 12:30 pm
Hi, im trying to start the runtime in a windows 10 virtual machine based on linux+kvm/libvirt but it doesent work..
Here is the output of the window
01500715638940: Cmp=CmpOPCUAServer, Class=1, Error=0, Info=0, pszInfo= **************************************************************
01500715638940: Cmp=CmpOPCUAServer, Class=1, Error=0, Info=0, pszInfo= OPC UA Server Started:
01500715638940: Cmp=CmpOPCUAServer, Class=1, Error=0, Info=0, pszInfo= Hostname: DESKTOP-4SOTATE, Port: 4840
01500715638940: Cmp=CmpOPCUAServer, Class=1, Error=0, Info=0, pszInfo= URL: opc.tcp://DESKTOP-4SOTATE:4840
01500715638940: Cmp=CmpOPCUAServer, Class=1, Error=0, Info=0, pszInfo= Loopbackadapter activated.
01500715638940: Cmp=CmpOPCUAServer, Class=1, Error=0, Info=0, pszInfo= All available networkadapters are used.
01500715638940: Cmp=CmpOPCUAServer, Class=1, Error=0, Info=0, pszInfo= Provider CODESYS_DefaultProvider with Version 0x3050b00 registerd at the OPC UA server.
01500715638940: Cmp=CmpOPCUAServer, Class=1, Error=0, Info=0, pszInfo= Provider CmpOPCUAProviderIecVarAccess with Version 0x3050b00 registerd at the OPC UA server.
01500715638945: Cmp=CmpBlkDrvTcp, Class=1, Error=0, Info=6, pszInfo= Local network address: <ipaddress>192.168.1.50</ipaddress>
01500715638945: Cmp=CmpRouter, Class=1, Error=0, Info=4, pszInfo= Network interface <interface>BlkDrvTcp</interface> at router <instance>1</instance> registered
01500715638947: Cmp=CmpRouter, Class=1, Error=0, Info=4, pszInfo= Network interface <interface>BlkDrvShm</interface> at router <instance>2</instance> registered
01500715638947: Cmp=CmpBlkDrvShm, Class=1, Error=0, Info=9, pszInfo= Local address (BlkDrvShm) set to <address>1</address>
01500715639384: Cmp=CM, Class=8, Error=0, Info=0, pszInfo=#### Exception occurred: CMInit
01500715639384: Cmp=CM, Class=1, Error=0, Info=35, pszInfo= CODESYS Control shutdown...
01500715639442: Cmp=CmpOPCUAServer, Class=1, Error=0, Info=0, pszInfo= Provider CODESYS_DefaultProvider with Version 0x3050b00 unregisterd at the OPC UA server.
01500715639588: Cmp=CmpOPCUAServer, Class=1, Error=0, Info=0, pszInfo= Provider CmpOPCUAProviderIecVarAccess with Version 0x3050b00 unregisterd at the OPC UA server.
01500715639590: Cmp=CmpRouter, Class=1, Error=0, Info=5, pszInfo= Network interface <interface>BlkDrvTcp</interface> unregistered
01500715639591: Cmp=CmpRouter, Class=1, Error=0, Info=5, pszInfo= Network interface <interface>BlkDrvShm</interface> unregistered
01500715639593: Cmp=CmpOPCUAServer, Class=1, Error=0, Info=0, pszInfo= ********************** Server OPC UA stopped! *************************
01500715639594: Cmp=CmpRouter, Class=1, Error=0, Info=5, pszInfo= Network interface <interface>ether 0</interface> unregistered
01500715639596: Cmp=CM, Class=1, Error=0, Info=36, pszInfo= CODESYS Control shutdown done
Gesendet von meinem Lenovo TAB 2 A10-70F mit Tapatalk
 Post subject: Re: Problem
PostPosted: Wed Jul 26, 2017 6:25 am
could not really identify why this happens is this current 3.5SP11 Version if not could you try it with this?
PostPosted: Wed Jul 26, 2017 9:43 am
It is sp11...
Gesendet von meinem Moto G Play mit Tapatalk
PostPosted: Tue Aug 01, 2017 2:04 am
I reinstalled the vm but no way.. still the same error
PostPosted: Sat Aug 12, 2017 3:33 am
2017-08-12 04:29:36: Handle 62 automatically released (no longer valid)
2017-08-12 04:29:46: Entry (101597:13) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)(ts)(Oskar,CODESYSControlService.exe) with NoUserLimit
2017-08-12 04:29:46: API Error 200 (ENTRY NOT FOUND) occurred!
2017-08-12 04:29:46: Access from local(IPV6)(ts)(Oskar,CODESYSControlService.exe) to FC:PC=5000304:13 with NoUserLimit (Handle 95)
2017-08-12 04:29:47: Access from local(IPV4) to SubSystem (Handle 96)
2017-08-12 04:29:47: Handle 96 released
2017-08-12 04:29:47: Access from local(IPV4) to IFI (Handle 97)
2017-08-12 04:29:47: Handle 97 released
2017-08-12 04:29:47: Access from local(IPV4) to SubSystem (Handle 98)
2017-08-12 04:29:47: Handle 98 released
2017-08-12 04:29:47: Entry (32767-3201 0:0) not found - Event WB0261 (LICENSE NOT ACTIVATED), Request IP-Address local(IPV4) with NoUserLimit
2017-08-12 04:29:47: API Error 261 (LICENSE NOT ACTIVATED) occurred!
2017-08-12 04:29:47: Access from local(IPV4) to IFI (Handle 100)
2017-08-12 04:29:47: Handle 100 released
2017-08-12 04:29:47: Access from local(IPV4) to SubSystem (Handle 101)
2017-08-12 04:29:47: Handle 101 released
2017-08-12 04:29:47: Access from local(IPV4) to SubSystem (Handle 102)
2017-08-12 04:29:47: Handle 102 released
2017-08-12 04:29:47: Access from local(IPV4) to IFI (Handle 103)
2017-08-12 04:29:47: Handle 103 released
2017-08-12 04:29:47: Access from local(IPV4) to SubSystem (Handle 104)
2017-08-12 04:29:47: Handle 104 released
2017-08-12 04:29:47: Access from local(IPV4) to IFI (Handle 106)
2017-08-12 04:29:47: Handle 106 released
2017-08-12 04:29:47: Access from local(IPV4) to SubSystem (Handle 107)
2017-08-12 04:29:47: Handle 107 released
