It is currently Tue Jun 18, 2019 10:54 am
PostPosted: Fri Apr 21, 2017 3:56 pm
Hi.
I bought three licences for the raspberry pi.
Per email i got the licence keys and wanted to add them in the engineering system to put them on the raspberrys.
But i canĀ“t do this. I got an Internal Error 10114: "context could not be properly read (No FirmUpdateCounter found for firm code 101597)".
The engineering system is a virtual machine with hyperV.
Programming and Updating of the raspberry pi was no problem.
The first problem occured by installing the licences.
I found no info about this error.
What's the reason for this?
Thanks!
PostPosted: Mon May 21, 2018 5:48 am
I've contacted Bug Support and have an open ticket for the same issue. Have you been able to solve your issue? I will gladly update if/when I find the fix.
PostPosted: Mon May 21, 2018 7:38 am
I was able to install the licenses directly to device instead of the License Manager method. Edit Licenses... option is available in PLC Settings of Device. Hope this helps.
