I'm trying to select a CANopen miniPICe card to be used in a PC with CODESYS RTE and CANopen Master and I need a reference of supported hardware for his configuration.
I can see there are two components CmpSJACanDrv and CmpHilscherCIFX than can be configured into de component manager of the RTE cgf file but I donβt know which hardware is compatible with it.
I guess the Hilscher CIFX 90E-CO\F can be driven with the CmpHilscherCIFX component
I also guess the PEAK PCAN-MiniPCIe IPEH-003048 can be driven with the CmpSJACanDrv
Is there any reference or some one of you had used any of this cards or other brand cards like IXXAT with CODESYS RTE?
not really - check the RTE documentation in generall only the SJA based cards are supported.
Another Option if there is no Slot available in your pc -
Ethercat CAN Gateway by EL6751.
