Author |
Message |
Ciprian
PostPosted: Fri Jun 10, 2016 10:06 am |
I have problems communicating with Siemens IM 151-3 PN v7.0 using Control Win 3.5.8.4. Can you tell me what the codes from "Station Status" means? Attached are pictures with Station Status and Diag Data.
Top |
Quang Loc
PostPosted: Tue Apr 17, 2018 7:10 pm |
Hello, I got the same issue but I don't know how to solve it? Did you have any solution or the something in order to fix this problem?
Thanks in advance
Top |
Ciprian
PostPosted: Wed Apr 18, 2018 6:48 am |
Yes, you can try to increase the Send Clock and the Reduction Ratio. Hope this will help you.
Top |
Quang Loc
PostPosted: Wed Apr 18, 2018 3:05 pm |
Thanks for your reply.
It works, but now I got some problem about the Siemens device. I don't have the file .xml of 6ES7-315-2FJ14-0AB0. I also created by Simatic Manager but it does not work.
Error: The correct import filter for the file could be not detected.
hope your help. thanks
Top |
Ciprian
PostPosted: Thu Apr 19, 2018 8:17 am |
I don't have Simatic Manager installed but I made a test using TIA Portal. I created an xml file for CPU315F-2 PN/DP + 1 DIx16 and it worked to import in Codesys.
What version of Codesys are you using?
Top |
radionica
PostPosted: Tue Apr 24, 2018 8:02 am |
Hi, I am using PFC200 and Wago's Profinet modules (five of them). I had to slow down Send Clock ... I still have problem with loosing "Online" after downloading new version of application. It seems that CPU doesn't have enough time to handle two Ethernet.
Top |
Edwin Schwellinger
PostPosted: Tue Apr 24, 2018 11:04 am |
Hi, yes I agree that PFC200 is from CPU performance limited to do profinet. In this case it is usually better to work for example with Ethercat and 350-354
BR Edwin
Top |
