Control RTE download Profinet application failed
2019-11-25
2019-11-26
  • XianXianXian - 2019-11-25
    I have an application with CoDeSys RTE and I use an Ethernet adapter, PN Controller as profinet master to connect with my profinet slave.
    I can compile this application without error. But when I try to login / download this application to PLC, I get unknown error.
    EXCEPTION [GlobalInit] code: App=[Application], Exception=[UNKNOWN]
    SOURCEPOSITION App=[Application] area=3, offset=234025
    In the Details, it is written Code-Position: LMPM.FindAdapterByMAC. Library: profinet.
    Can someone please help me have a look, why I have this error? Thank you.
    More info please see attached screenshot, log and PLC config file.
    Environment:
    Windows 10
    CoDeSys RTE 3.5.14.20
    Network card : Realtek PCIe GbE Family; Driver: CmpRTL8169Mpd
    IMG: Profinet error.PNG
    Control RTE config.txt [1.78 KiB]
    Control RTE log.xml [68.82 KiB]
    eschwellinger - 2019-11-25
    possible to check if the 3.5.15.20 version works ok?
    You need to update RTE version CODESYS Developmentsystem and Project - needs to be updated to -> update device on the PN-Controler and PLC
  • XianXianXian - 2019-11-26
    Hi Edwin,
    thank you very much, it works.
    Now I can download the application.
    Best regards
    Xianxian
