PFC200 - Modbus RTU - RS485
Damian7546
2019-10-06
2019-10-07
  • Damian7546 - 2019-10-06
    Can anybody write step by step what can I do to run Modbus Master in my WAGO PFC200 ?
    My slave is still : Not running as in attachment picture.
    I should set RS485 interface , where ?
    IMG: wago_modbus.jpg
  • eschwellinger
    eschwellinger - 2019-10-06
    use the plc shell...
    IMG: serialmodePFC.png
    Probably it is ok:
    I checked and the rs485 is selected.
    IMG: test_rs.jpg
    Only result:
    IMG: test_rs485.jpg
  • eschwellinger
    eschwellinger - 2019-10-07
    1. check wiring
    2. check baudrate in CODESYS under 'Modbus_Com'
    3. Check Slave Diagnosis in CODESYS see screenshot
    IMG: ModbusSlaveDiag.png
  • Damian7546 - 2019-10-07
    is better:
    Time to time in "byModbusError " = UNDEFINED but usually is RESPONSE_SUCCES.
    I tried pooling my slave device by other master device with parameter:
    9600/8/N/1 , Slave ID=2, Function=3, Offset =31, lenght =10. an I got response 12,12,22,11,33 ..
    When I set above parameters in WAGO /Codesys the slave not response . When I change function code to 4 i Get response but only 0,0,0,0, like in attachment picture....
    IMG: zdj_test.jpg
  • eschwellinger
    you need to map variables or switch to always update for testing purpose.
    We see on your values the are 'light grey' - means not updated.
    thanks it works.
